bhusick Offline Upload & Sell: On
| p.1 #1 · Sold: Apple MacBook Air 13" $375 | |
 | Item Sold
Price: $375.00 Payment method: PayPal Item condition: 7 Shows considerable amount of use - More than average wear Shipping instructions: ground
Hi, I am selling my original 2008 MacBook Air 13" with 2GB RAM and 64GB SSD. It's in good shape except for the right side hinge which is a little bent and wonky - the screen stays in the position you choose, but the hinge is clunky and bent. There are no dead pixels or broken keys or ports. There is a little ghosting in the center of the screen. There are marks on the surfaces, but nothing big. I had ZAGG shield on it from day one and I just removed it (it was yellowing). I would rate it overall about a 6 or 7 out of 10, but I am very picky. The hinge would cost $300 to fix, so I decided not to do it.
I just had Apple install a brand new battery (at a cost of $149) and otherwise it works very well. It would make a great coffee-shop web machine or writing notebook. Battery life is outstanding at nearly 5 hours.
I bought it new for more than $3000 when it was introduced, but I am selling it here AS IS with power adapter for $400 shipped ground in CONUS, paypal. That's cheaper than most iPads. I believe I have Snow Leopard running on it.
No trades or lower offers please.
Below are the complete specs:
Introduction Date: January 15, 2008* Discontinued Date: October 14, 2008
Processors: 1 (2 Cores) Geekbench: 1800/2445*
Processor Speed: 1.8 GHz Processor Type: Core 2 Duo (P7700)
Custom Speeds: N/A Architecture: 64-Bit
Processor Upgrade: Soldered FPU: Integrated
System Bus Speed: 800 MHz Cache Bus Speed: 1.8 GHz (Built-in)
ROM/Firmware Type: EFI EFI Architecture: 32-Bit
L1 Cache: 32k/32k L2/L3 Cache: 4 MB (on chip)
RAM Type: DDR2 SDRAM* Min. RAM Speed: 667 MHz
Standard RAM: 2 GB Maximum RAM: 2 GB
Motherboard RAM: 2 GB RAM Slots: None
Video Card: Intel GMA X3100 VRAM Type: Integrated
Standard VRAM: 144 MB Maximum VRAM: 144 MB
Built-in Display: 13.3" Widescreen Native Resolution: 1280x800
2nd Display Support: Dual/Mirroring 2nd Max. Resolution: 1920x1200
Standard Hard Drive: 64 GB (SSD) Int. HD Interface: Parallel ATA (ZIF)
Standard Optical: None* Standard Disk: None
Standard Modem: None* Standard Ethernet: None*
Standard AirPort: 802.11a/b/g/n Standard Bluetooth: 2.1+EDR
USB Ports: 1 (2.0) Firewire Ports: None
Expansion Slots: None Expansion Bays: None
Incl. Keyboard: Full-size Incl. Input: Trackpad (3-Finger)
Case Type: Notebook Form Factor: MacBook Air
Apple Order No: BTO/CTO Apple Subfamily: MacBook Air - Original
Apple Model No: A1237 (EMC 2142*) Model ID: MacBookAir1,1
Battery Type: 37 W h Li-Poly Battery Life: 5 Hours
Pre-Installed MacOS: X 10.5.1 (9B2324) Maximum MacOS: X 10.7.5*
Minimum Windows: XP SP2 (32-Bit)* Maximum Windows: 7 (32-Bit)**
MacOS 9 Support: None Windows Support: Boot/Virtualization
Dimensions: .16-.76 x 12.8 x 8.94 Avg. Weight: 3.0 lbs (1.36 kg)
Original Price (US): US$3098* Est. Current Retail: US$650-US$750
Edited on Dec 22, 2012 at 09:47 PM · View previous versions
