timbop Offline Upload & Sell: On
p.1 #6 · Shooting "Torch Parade with Fireworks" at ski area: settings? | |
The good news is that the little screen on the back of the camera can help you zone in on the right settings, but as a starting point I would try the 24-105 with IS on at f/4, 1/20, and ISO 6400. If all you want to see is the path of the torches with a trail, then you might be able to cut ISO down to 3200 or 1600, but to get the visible trails you'll need a longer exposure. You'll need to brace yourself at that point. I would also suggest trying to get shots where you can see the skiers as the get close to you by upping the ISO and/or using flash - but to keep from blinding them hit them from the side with a speedlite. If you do plan to use the flash, set power manually and enable the second curtain sync, and then using a slower exposure (1/20 or so) and medium ISO (1600/3200) you'll get a nice flame trail and a stop-action of the skier
