Archive 2012 · D800E malfunction
gurtch
p.1 #1 · p.1 #1 · D800E malfunction
I used the camera yesterday, and all seemed fine. Today, if I take a picture, it shows up on the screen, but then stays there, and never goes away. Also the replay does not work, nor does the menu button. Screen stays blank.
Any suggestions? I will need to switch systems. I have two SD cards with many images, the cards were formatted in the Nikon. can I use the cards in a Sony A900 without reformatting? reason I ask, is we are still homeless after Sandy. I want to leave the images on the cards because I have no back up capability, I am living with a notebook PC intil I can return home.
camera under warranty, but I hate to send it away.
Thanks
Dave
Nov 26, 2012 at 05:15 PM
ckcarr
p.1 #2 · p.1 #2 · D800E malfunction
Sure your cards are not full?
Nov 26, 2012 at 05:47 PM
JimFox
p.1 #3 · p.1 #3 · D800E malfunction
Is the "play" button stuck in?
Nov 26, 2012 at 06:33 PM
James R
p.1 #4 · p.1 #4 · D800E malfunction
Turn off the camera and remove the cards. Put another card in, format it, and then take a picture. If it works fine, then you have two full cards. Then put your full cards in a baggie and leave them in your camera bag until you can up load them. Better to have clean cards in your camera encase you need to capture more images or document your return home.
Sorry for the troubles you and your neighbors are going through. Hope you get home soon.
Jim
Nov 26, 2012 at 08:43 PM
Scott Grant
p.1 #5 · p.1 #5 · D800E malfunction
My thought also. I had two D700's with sticky 'Play' buttons and they showed the same symptoms.
Nov 26, 2012 at 08:46 PM
playerofwar
p.1 #6 · p.1 #6 · D800E malfunction
Maybe just pulling out the battery when the camera is on might do the trick.
Nov 26, 2012 at 09:39 PM
james.d53
p.1 #7 · p.1 #7 · D800E malfunction
Electronics are strange sometimes. Hope it is just a hiccup, but if it's not. You can almost walk to the Nikon repair center (figuratively of course)! I have to send mine to CA.
Hope you and your family get back to normal soon!
Nov 27, 2012 at 01:24 AM
gurtch
p.1 #8 · p.1 #8 · D800E malfunction
Thanks all. Tried all the above, then gave up. UPS picked up tonight, delivery tomorrow guaranteed to Nikon. I do not know their turn around, but hope to have it back soon.
best regards
Dave
Nov 27, 2012 at 03:42 AM
gurtch
p.1 #9 · p.1 #9 · D800E malfunction
best regards
Dave
