Archive 2012 · YN 560 II and ST-E2
musclepics
p.1 #1 · YN 560 II and ST-E2
Does anybody know if the YN-560 II flash can be triggered (in manual mode) by the Canon St-E2 infrared receiver (or even the infrared system on the 580 II if it was master on camera and you wanted to trigger the YN-560 as slave)?
Or does the YN-560 II only work as an optical slave?
I have an ST-E2 and 430EX II and want to use the 2 flashes together fired by the ST-E2. Again, not using ETTL just manual mode.
Nov 15, 2012 at 11:24 PM
uzet1
p.1 #2 · YN 560 II and ST-E2
The ST/580 won't trigger it via infra, but you can use the 560II in manual mode+optical slave, so as you tigger the 430 with your ST, the YN560 will flash too.
Other option is to get the newer YN560EX (I put a short review here) who supports ETTL via infra red, therefor your ST will control it.
The YN560EX costs about 90$ but I think it worth the extra 20$ (over the YN560II)
Nov 18, 2012 at 10:57 AM
musclepics
p.1 #3 · YN 560 II and ST-E2
Thanks Uzet1, that's exactly the information I was looking for!
Nov 20, 2012 at 08:39 PM
BrianO
p.1 #4 · YN 560 II and ST-E2
uzet1 wrote:
...you can use the 560II in manual mode+optical slave, so as you tigger the 430 with your ST, the YN560 will flash too.
Won't the command & control preflashes of the ST-E2 cause a premature triggering of the YN560? Or can it be set to ignore the preflashes?
Nov 20, 2012 at 09:16 PM
musclepics
p.1 #5 · YN 560 II and ST-E2
From what I understand, with the 560 and 560II there are 2 optical triggers, one for use when there is no preflash, and one for when there is.
But the YN560EX will work with infrared from the ST-E2 trigger just like a normal Canon flash, with TTL included! Just no HSS.
Nov 21, 2012 at 05:36 PM
