Jman13 Offline Upload & Sell: On
p.1 #9 · Panasonic 35-100mm f/2.8 | |
Well, I've had a chance to shoot a little bit more with it. I need to shoot quite a bit more with it, but there are some odd inconsistencies I haven't had before. I went out for a while, using the OIS instead of the IBIS for a while, and at very high shutter speeds (1/4000s, 1/3200s), the IS can occasionally interfere with the image and cause a little softening. I went out again later, using IBIS, though it was in dimmer light. I have noticed that at 100mm and f/2.8, sometimes it seems to miss focus at longer distances. It's something I haven't experienced on Micro 4/3 before, though it's also possible there was some other stuff, so much more testing and shooting is needed. Shooting indoors with flash in dim light, the AF was dead on accurate, and the lens was very sharp, so I need to figure out if it was just my unfamiliarity with the lens, or if it was just occasional silly things with the OM-D. Overall, most shots at f/2.8 were plenty sharp (though not razor sharp), and f/4 tended to be extremely sharp. Overall, image quality appears to be quite high. It's sharper at the wider end, and a little softer at the long end. I had no apparent focus issues at the 35-50mm range.
Some samples:
Ivy at 100mm, f/4 - about 5-8 feet focus distance:
100% center crop:
100% upper right crop:
At infinity (or close enough), and f/2.8, 100mm:
100% center crop:
100% edge crop:
Same framing, but at f/4:
100% center crop:
100% edge crop:
Then I took a few sample shots at 100mm f/2.8 indoors with flash:
At about 5 feet:
Another:
100% crop of above:
And closer:
100% crop of above:
