Nikon 14-24 vs new zeiss 15mm
DanPBrown
p.1 #1 · Nikon 14-24 vs new zeiss 15mm
Howdy all, I've been away from photography for a while and I just noticed Zeiss introduced a new 15mm. How does it compare to Nikon 14-24?
Thanks,
Nov 15, 2012 at 12:50 PM
Phillip Reeve
p.1 #2 · Nikon 14-24 vs new zeiss 15mm
http://www.3d-kraft.com/index.php?option=com_content&view=article&id=127:uwa-comparison&catid=40:camerasandlenses&Itemid=2
Nov 15, 2012 at 01:02 PM
phuang3
p.1 #3 · Nikon 14-24 vs new zeiss 15mm
Samyang 14/2.8 is pretty impressive, almost APO corrected. Zeiss is a bit overpriced. If it is around 1500~1700, I might consider buying one.
Nov 15, 2012 at 01:58 PM
magiclight
p.1 #4 · Nikon 14-24 vs new zeiss 15mm
The Zeiss 15mm seems to be brilliant wide open. Clearly better than the 14-24mm. However once stopped down the 14-24mm has the edge.
Nov 17, 2012 at 07:35 AM
thrice
p.1 #5 · Nikon 14-24 vs new zeiss 15mm
The Tokina 16-28 is sharper than the Nikon 14-24 as well.
Nov 17, 2012 at 12:20 PM
alundeb
p.1 #6 · Nikon 14-24 vs new zeiss 15mm
The Center crops from the NEX 7 at f/5.6 a little down the page show the opposite. The Zeiss 15 is much sharper than the 14-24 there.
Nov 17, 2012 at 02:10 PM
snapsy
p.1 #7 · Nikon 14-24 vs new zeiss 15mm
Every time a new lens is put up against the 14-24 there are claims the new lens is better, and every time those claims turn out to be wrong. The 14-24 is still the sharpest UWA lens in the word across the frame, esp. at the stopped-down apertures that is typical for its use.
Here are photozone's 14-24 and 16-28mm results btw. At the wide end it's not even close:
NIkon 14-24
Tokina 16-28
Nov 17, 2012 at 03:05 PM
alundeb
p.1 #8 · Nikon 14-24 vs new zeiss 15mm
It will be interesing to see the numbers from photozone on the Zeiss 15, since they refocus to eliminate curvature of field. In my experience the Zeiss 15 is quite heavy at it.
Nov 17, 2012 at 03:21 PM
hiepphotog
p.1 #9 · Nikon 14-24 vs new zeiss 15mm
Very likely due to focus shift. This is well-documented by Lloyd Chambers.
Nov 17, 2012 at 04:49 PM
RustyBug
p.1 #10 · Nikon 14-24 vs new zeiss 15mm
Optics in general ... UWA in particular is always a series of compromises / tradeoffs.
The bane of the NIkon is distortion, Zeiss vignetting, Tokina, softer corners. Nobody makes a lens that handles all of these simultaneously. COF and other optical issues are also part of the equation.
For me, the issue isn't picking the one that is the best amongst the good ... instead, pick your poison (resolution, distortion, vignetting, cof, flare, etc.) and stay away from it, or at least have a strategy for dealing with it.
To me, the Nikon has more distortion, the Zeiss more vignette and the Tokina has nervous bokeh, while the Samyang has more distortion as those things that "put me off".
A few from the TDP:
Tokina 16-28 vs. Nikon 14-24
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=773&Camera=453&Sample=0&FLI=0&API=0&LensComp=615&CameraComp=614&SampleComp=0&FLIComp=2&APIComp=0
Zeiss 15 vs. Nikon 14-24
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=794&Camera=453&Sample=0&FLI=0&API=0&LensComp=615&CameraComp=614&SampleComp=0&FLIComp=1&APIComp=0
Zeiss 15 vs. Samyang 14
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=794&Camera=453&Sample=0&FLI=0&API=0&LensComp=769&CameraComp=0&FLIComp=0&APIComp=0
Zeiss 15 vs. Samyang 14 (Distortion)
http://www.the-digital-picture.com/Reviews/Lens-Distortion.aspx?FLI=0&FLIComp=0&Lens=794&Camera=453&LensComp=769
Nov 17, 2012 at 04:53 PM
redisburning
p.1 #11 · Nikon 14-24 vs new zeiss 15mm
just curious, why would there be focus shift on a nex-7? I would think you would stop down to the aperture you wanted to shoot at and then focus for the highest level of contrast. especially if you are doing a test where you want to take the time to show each lens at it's best.
Nov 17, 2012 at 05:03 PM
hiepphotog
p.1 #12 · Nikon 14-24 vs new zeiss 15mm
You caught me right there . They did not really say how they focused. So I automatically assume that they focused and stopped down metering like in the old day. But with the LV and manually aperture control, the focus shift argument is not valid.
Nov 17, 2012 at 05:11 PM
Keith B.
p.1 #13 · Nikon 14-24 vs new zeiss 15mm
Wouldn't the image softening due to the presumed focus shift be more visible with the NEX examples, due to a greater degree of enlargement?
Nov 18, 2012 at 04:31 AM
edwardkaraa
p.1 #14 · Nikon 14-24 vs new zeiss 15mm
The only response that makes sense is that of rustybug. Agree 100%.
Nov 18, 2012 at 04:36 AM
philip_pj
p.1 #15 · Nikon 14-24 vs new zeiss 15mm
Nikon may have done better if they made the 14-24 an f4 lens, as the res wide open is very poor, and the CA is disturbing. Perhaps they may have been able to fit a filter ring to it then and make it a reasonable weight and size. In this day an age it is starting to look like a dinosaur. It also costs $2000. Focus shift will become a more serious matter with the new sensors now emerging, and Nikon DSLRs still use OVFs I believe.
It has fine sharpness at middle apertures and that seems enough to please many fans, but images are clinical and lack the vitality, fine colour and contrast that the CZ lens brings with it. The Samyang is terrific value.
That DP site really need to ensure that scaling and exposure of test images is at least the same for each lens. The Nikon has nasty CA even at f11 in their images.
Regarding Kent's trade-offs, many users add vignetting to images or are ambivalent about it, but not many wish to add CA or distortion. Apologies in advance if I make no sense Ed, it wouldn't be the first time!
Nov 18, 2012 at 06:23 AM
edwardkaraa
p.1 #16 · Nikon 14-24 vs new zeiss 15mm
You make perfect sense, Philip!
Nov 18, 2012 at 06:51 AM
pdmphoto
p.1 #17 · Nikon 14-24 vs new zeiss 15mm
Having owned excellent copies of the Nikon 14-24/2.8 and the Tokina 16-28/2.8, I'd say that center sharpness is better on the Tokina, and corner sharpness is about equal (on a 5DII). They are very close though, especially at the corners, and copy to copy variation probably plays more of a role than anything else. I really prefer the better color and contrast (including micro-contrast) of the Tokina , and the 16-28 focal range.
Nov 18, 2012 at 08:34 AM
RustyBug
p.1 #18 · Nikon 14-24 vs new zeiss 15mm
Paul ... been a while.
So you like the Tokina on your SLR/C ?
It's been on my radar (research based), but I've not had the occasion to try one out yet. Would love to see some of your work with it (remembering your WA Tamron stuff from quite a while back) as we have some similar perspectives.
Nov 18, 2012 at 03:25 PM
