d600 autofocus stops working
boshek
p.1 #1 · d600 autofocus stops working
D600 with Nikon 70-200 2.8. In the middle of a shoot and NO autofocus. Turned camera on and off, changed from autofocus to manual and back several times on body as well as on lens. NOTHING. Changed to 24-70 lens and autofocus is fine. Put 70-200 on D700 and autofocus is fine................what gives??/
Nov 10, 2012 at 07:40 PM
borisb
p.1 #2 · d600 autofocus stops working
did you try mounting/unmounting the lens? there could have been some gunk on the electrical contacts. I find that the tolerances built into the lens mount specifications occasionally allow for lenses to jiggle around enough to interrupt or otherwise throw off the communication between body and lens.
Nov 10, 2012 at 08:06 PM
boshek
p.1 #3 · d600 autofocus stops working
nice boris!! after I switched lenses and bodies then lens/body worked fine. I dont have a clue, it worked fine for an hour and then just stopped.
Nov 11, 2012 at 03:11 AM
LarryM
p.1 #4 · d600 autofocus stops working
My neighbor's 2 week old D600 also stopped autofocusing. We tried multiple lenses without success so he sent it back to the dealer. Dealer also had no success and replaced the camera.
We hope these are isolated incidents and not a new production problem.
Nov 14, 2012 at 12:33 AM
boshek
p.1 #5 · d600 autofocus stops working
70-200 now REFUSES to focus on d600, 24-70 is fine. taking the 70-200 to Nikon today.
Nov 19, 2012 at 10:20 AM
boshek
p.1 #6 · d600 autofocus stops working
$420 to clean and check wtf?
Nov 19, 2012 at 03:43 PM
NightOwl Cat
p.1 #7 · d600 autofocus stops working
Who gave you that quote
Nov 19, 2012 at 03:59 PM
boshek
p.1 #8 · d600 autofocus stops working
nikon- standard charge for that lens
Nov 19, 2012 at 05:09 PM
OneLightStand
p.1 #9 · d600 autofocus stops working
I just took a bunch of shots w/my 70-200 and have found the single point focus is off...I'm still evaluating if it's my error or the D600.
Please update on your/Nikons findings...
Nov 20, 2012 at 02:39 PM
NightOwl Cat
p.1 #10 · d600 autofocus stops working
I'd call APS and see what they would charge before I shipped it off to Nikon. You'd probably even get it back faster from them Hope your luck with camera equipment changes.
Nov 20, 2012 at 02:56 PM
boshek
p.1 #11 · d600 autofocus stops working
my lens doesnt focus at all. no motor movement, nutin.
Nov 20, 2012 at 10:37 PM
boshek
p.1 #12 · d600 autofocus stops working
I dropped it off for a FREE estimate. Where is aps
Nov 20, 2012 at 10:38 PM
robert829
p.1 #13 · d600 autofocus stops working
HUUUUUUH!!!!!!
Nov 20, 2012 at 10:43 PM
NightOwl Cat
p.1 #14 · d600 autofocus stops working
APS is in Morton Grove, Illinois, their web site is http:/www.nikoncamerarepair.com
They do great work and quickly.
Nov 20, 2012 at 10:47 PM
boshek
p.1 #15 · d600 autofocus stops working
thanks, called them, they do a clean and check starting at $15-$45. thats a little less than Nikon's $400. I should have just sent it there. thanks for the help, Mike
ps the most expensive repair( a new motor) is around $500.
Nov 20, 2012 at 11:06 PM
boshek
p.1 #16 · d600 autofocus stops working
robert829 wrote:
HUUUUUUH!!!!!!
yep!!
M Lucca
p.1 #17 · d600 autofocus stops working
Check if the switch is in AF instead of M. Seems obvious.
Nov 20, 2012 at 11:18 PM
boshek
p.1 #18 · d600 autofocus stops working
If only I was that lucky..............
Nov 21, 2012 at 12:07 AM
trenchmonkey
p.1 #19 · d600 autofocus stops working
Mike, have you thoroughly cleaned the contacts You'd be surprised all the crap that comes off 'em straight out of the box
Took a Q-tip to my buddy's D600 (~500 clicks) A little CRC QD Contact Cleaner and both tips were black when I was done
You pick a direction and do multiple passes until clean. It sucks one has to go thru this with a new body/lens but I'd sure
give it a go before sending it in. HTH, Will
Nov 21, 2012 at 12:27 AM
boshek
p.1 #20 · d600 autofocus stops working
I did not Will, didnt want to make it worse but as soon as I get it back from Nikon I will do that(unless of course they do it for me) ty
ps you missed one helluva storm!!
95 mph wind in Eatons Neck
Nov 21, 2012 at 01:06 AM
