OMD & Panalecia 25 1.4 - need adapter??
cannpope
p.1 #1 · OMD & Panalecia 25 1.4 - need adapter??
Do you need an adapter to use the Panalecia 25 1.4 on the OMD? New to the m4/3 system.
Thanks!
Nov 08, 2012 at 05:13 PM
mcbroomf
p.1 #2 · OMD & Panalecia 25 1.4 - need adapter??
It's an m4/3 lens so no adapter req'd
Mike
Nov 08, 2012 at 05:16 PM
cannpope
p.1 #3 · OMD & Panalecia 25 1.4 - need adapter??
Thanks!
Nov 08, 2012 at 05:21 PM
Jman13
p.1 #4 · OMD & Panalecia 25 1.4 - need adapter??
Just be careful and make sure you get the (less expensive) Micro 4/3 mount Panaleica 25/1.4. There is a 4/3 mount Panaleica 25/1.4, which is also quite good, but more expensive, larger and WOULD require an adapter.
Nov 08, 2012 at 06:19 PM
cannpope
p.1 #5 · OMD & Panalecia 25 1.4 - need adapter??
The one I'm looking at is $500. It's the Summilux ASPH.
Nov 08, 2012 at 07:27 PM
carstenw
p.1 #6 · OMD & Panalecia 25 1.4 - need adapter??
I guess you mean the DG Summilux ASPH, not the D Summilux ASPH? Summilux just means f/1.4, and almost all recent Leica lens designs have aspherical elements, including both the 4/3 and Micro-4/3 designs.
Nov 08, 2012 at 07:53 PM
cannpope
p.1 #7 · OMD & Panalecia 25 1.4 - need adapter??
Yea. It's the DG.
Nov 08, 2012 at 08:02 PM
carstenw
p.1 #8 · OMD & Panalecia 25 1.4 - need adapter??
That one is Micro Four Thirds and works directly on the Olympus OM-D E-M5.
Nov 08, 2012 at 08:16 PM
FlyPenFly
p.1 #9 · OMD & Panalecia 25 1.4 - need adapter??
Interestingly some people consider the older bigger version to be superior. But I bet it focuses slowly on MfT if at all.
There is more glass in the older one and it covers the same sensor size. Not that I would ever trade mine.
Nov 09, 2012 at 07:04 PM
Jman13
p.1 #10 · OMD & Panalecia 25 1.4 - need adapter??
Most tests I've seen show the m4/3 version to be the better lens. It's certainly much smaller too (the 4/3 version is frankly huge).
Nov 09, 2012 at 08:10 PM
