Bag for 2 bodies and 3 lenses
Tareq
p.1 #1 · Bag for 2 bodies and 3 lenses
Hi all,
Anyone can recommend me a hard case bag for 2 bodies [Canon 1-series] and 3 lenses [1long prime such as 300 or 400, and 70-200 and 24-70L]?
I Prefer if you can recommend me Pelican brand, but i will go with others, i have Think Tank bag but not hard case one.
Thanks
Nov 06, 2012 at 07:37 AM
Mike K
p.1 #2 · Bag for 2 bodies and 3 lenses
There are many, many bags that will fit 2 bodies and with several larger lenses. However, one consideration rarely talked about is the depth of the bag, not its width/height dimensions. A 1D series body with an L bracket is at least 6.25 X 6.25 " in width X height, and many popular camera bags are not 6.25" deep. Even worse, many large primes (ie 400 f2.8) have very large diameter hoods on the order of 7". Very few camera bags are 7" deep. Of course you can stuff a smaller bag with a 7" high lens, but this puts the lens/hood in a much more vulnerable spot, should it be sandwiched under another heavy object. For sure another negative for the thinner bag will be that the zipper will be stressed when closing the bag, and the cover zippers are always the part that fail first.
Mike K
Nov 06, 2012 at 07:42 PM
Tareq
p.1 #3 · Bag for 2 bodies and 3 lenses
True!
Well, i have ThinkTank bag, but it is very tight and i feel the bag will break or crack by the time i keep squeezing the lenses inside and the bodies too, also it is not a hard case, in sports fields i see almost all the shooters using hard cases, only those with 1 body and 1 average lens using backpack, so i want to go with hard case as well, it will save me also carrying a small chair, so i can sit on that hard case bag.
Nov 06, 2012 at 07:54 PM
pixelrandy
p.1 #4 · Bag for 2 bodies and 3 lenses
Trying not to hijack this post -
@ Tareq - What Think Tank Bag are you using, and what are you trying to pack into it? None of our bags will crack, at least not by loading. There is some ABS that could potentially crack if it were run over by a car I suppose, but it would never crack from packing or hard use. Your gear will break first from being overly compressed if you're worried the bag is going to fail.
Let me know if you need help with this. You can email me (just put it to my attention) at cs@thinktankphoto.com.
Our rolling camera bags aren't soft, but they're not hard cases that are designed to be thrown into a river while hitting a rock or two on the way to the water. They can certainly be gate-checked, stacked, jumped on, but I still would never recommend one of our rolling camera cases for someone who specifically needs a HARD hard case.
Kind regards,
Randy
Randy Wentzel
Product Specialist & Photographer
thinkTANK photo
1105 N. Dutton, Suite C
Santa Rosa, CA 95401
www.thinktankphoto.com
customerservice@thinktankphoto.com
(866) 558-4465 Ext. 1
Nov 07, 2012 at 06:46 PM
Tareq
p.1 #5 · Bag for 2 bodies and 3 lenses
Hello Randy,
I have Think Tank Airport Security 2.0 bag, but honestly speaking, i will use it only if i travel or don't shoot sports, because in shooting sports i prefer to go with a hard case bag for some reasons, if Think Tank has a hard case bags that i can use to fit my sports shooting gear that will be a great news for me.
Nov 14, 2012 at 09:46 AM
KFG1
p.1 #6 · Bag for 2 bodies and 3 lenses
http://www.cambags.com/ this might help
Nov 14, 2012 at 03:42 PM
Tareq
p.1 #7 · Bag for 2 bodies and 3 lenses
Thank you very much!
That helped a lot, appreciate it so much!
Nov 14, 2012 at 07:17 PM
