Moderated by: Steve Tinetti, Fred Miranda
Wedding Resource List
OT: Help my LR 4.2 fly - whats in your box?
morganb4
p.1 #1 · OT: Help my LR 4.2 fly - whats in your box?
***this is not a 'I deleted my preferences file and its all better' thread. This is purely about the hardware platform on your PC if you have a copy of LR that has no/little slider lag in the develop module.
Do you have an installation of Lightroom 4.2 on your PC that in your opinion is well fast and has excellent responses in the develop module.
If so please post (privately if you want) your MB model & socket, RAM model and CPU. I am particularly interested in single-die quad-core solutions on gigabyte boards but I will take what I can get.
TIA
Ben
Edited on Nov 02, 2012 at 02:53 AM · View previous versions
Nov 01, 2012 at 02:50 AM
Scott Mosher
p.1 #2 · OT: Help my LR 4.2 fly - whats in your box?
I'm running
- Asus P8Z77-M Pro motherboard
Intel i7 2700k @ 3.5gh
Crucial Ballistix Sport DDR3-1600 (PC3-12800) dual channel memory (4x4GB modules)
OS, LR, some programs installed on SSD #1
SSD #2 scratch disk with LR/windows cache
LR 4.2 flies on my machine. Almost no delay when changing images in develop pane.
Nov 01, 2012 at 03:30 AM
morganb4
p.1 #3 · OT: Help my LR 4.2 fly - whats in your box?
Thanks!....Even the noise sliders are good?
Nov 01, 2012 at 03:33 AM
SloPhoto
p.1 #4 · OT: Help my LR 4.2 fly - whats in your box?
Im running..
i5 2500K @3.6ghz (I think, could be 3.8)
16gb ram
2 ssd drives
I would NOT say that it flies, and unfortunately upgrades from where I am get pricey fast.
(I do use a custom built nas for files, but the cache is on the second ssd and my delays are mostly cpu based it seems)
Nov 01, 2012 at 08:02 AM
D. Diggler
p.1 #5 · OT: Help my LR 4.2 fly - whats in your box?
How do you define "good"? When looking at an image at 100%, what's acceptable lag for display of a noise-reduction change?
Nov 01, 2012 at 08:29 AM
Scott Mosher
p.1 #6 · OT: Help my LR 4.2 fly - whats in your box?
Noise sliders are great. I can move it back & forth and see the change happen almost instantly
Nov 01, 2012 at 01:53 PM
amonline
p.1 #7 · OT: Help my LR 4.2 fly - whats in your box?
I know my specs are beyond what you inquired on, but I thought you may be able to compare to others.
Intel i7-980X Extreme Gulftown 3.33GHz Six-Core Processor Overclocked to 4.0GHz
ASUS Rampage III Extreme 6Gb/s USB 3.0 ATX Motherboard
Corsair Dominator-GT 12GB (6 x 2GB) DDR3 SDRAM 1866 RAM with Airflow Fan
(2) Intel X25-M Mainstream 2.5" 160GB SATA II Internal Solid State Drive (SSD) in RAID0
Microsoft Windows 7 Ultimate 64-bit
I didn't list my storage drive because I typically run everything from the OS drive and manually backup to the internal drive sporadically. Regardless, it plays no role in the performance.
As I've mentioned in the past, I've tried the SSDs as JBOD and RAID0. There was no difference. I was just too lazy to swap back to JBOD after I setup the RAID. Obviously, newer SSDs would be able to improve that area.
The machine is obviously scorching fast. During LR4.1 I deleted the preference file and purged all memory. That was the main thing that fixed LR. LR4.2 has retained the speed without a hiccup. My mobo also allows me to do all the BIOS-side tweaks mentioned across the web. I did similar adjustments when I built the machine a year ago. Running tests against others with similar spec levels has shown that the only bottleneck is now the processor. Since it's Intel's 3rd fastest processor (at one year old), I have no desire to upgrade for at least another year or two. (knocking on wood)
With regard to your inquiry, I have no delays in development at all. No sliders delay for me at any time. They did on the initial release of LR4.0. The only thing that will slightly slug for me personally is the brush if I have it set to auto-mask. Of course, this is where I'm my own worst enemy. I do my healing and cropping on my last pass. Swapping back and forth between these two tools is probably the hardest thing on the system. However, I still get through a wedding (cropping & cloning) in about an hour. That's cropping an average of 500 images and cloning probably 20-25% of them.
LR still exhibits the few seconds delay upon the first load of the develop module. Apparently, this is something Adobe cannot fix as it's done this for the entire LR4 release so far. It started that with the new process in 4.0. However, that is the only delay I experience. Moving image to image is practically instant.
Hope that helps in some way.
Nov 01, 2012 at 04:50 PM
D. Diggler
p.1 #8 · OT: Help my LR 4.2 fly - whats in your box?
At 100% view?
Nov 01, 2012 at 07:13 PM
Scott Mosher
p.1 #9 · OT: Help my LR 4.2 fly - whats in your box?
D. Diggler wrote:
At 100% view?
Yep
Nov 01, 2012 at 07:54 PM
amonline
p.1 #10 · OT: Help my LR 4.2 fly - whats in your box?
The one slider that takes a second to show the difference is my luminance slider in the noise reduction. I sometimes bump that to about 20 on very high ISOs. That takes about 1.5 seconds to show.
Nov 01, 2012 at 08:42 PM
BGP1
p.1 #11 · OT: Help my LR 4.2 fly - whats in your box?
Scott Mosher wrote:
D. Diggler wrote:
At 100% view?
Yep
Mine too. Similar specs except it's not a "k" processor(which I guess you can overclock?) mine is just an off the shelf Dell XPS 8500 I7 with 16 gigs of ram. No SSD to speak of as of yet and I pulled some images up zoomed to 100% and went to town with the sliders and changes happen real time.
Nov 01, 2012 at 08:44 PM
amonline
p.1 #12 · OT: Help my LR 4.2 fly - whats in your box?
lol I just checked and found my problem. If you type in numbers in the luminance, it takes longer. My sliders actually do work almost instant. I'd say it updates in less than half a second. I gotta get a hold on my OCD and number typing.
Nov 01, 2012 at 10:27 PM
SloPhoto
p.1 #13 · OT: Help my LR 4.2 fly - whats in your box?
I cleaned up my catalog and preferences and my system does a bit better.
I may start culling and editing on the ssd before I push files out to the nas.
Nov 01, 2012 at 10:47 PM
morganb4
p.1 #14 · OT: Help my LR 4.2 fly - whats in your box?
Thanks:-) It is helpful. Scotts build is interesting me....
Nov 02, 2012 at 02:54 AM
swoop
p.1 #15 · OT: Help my LR 4.2 fly - whats in your box?
Lightroom 4.2 runs fairly well on mine. I haven't check the response times for lag but it works well enough that it doesn't bother me.
Lenovo X230 laptop
12.5" 1366x768 LCD
2.9Ghz Dual Core i7
16GB of DDR3 RAM
480GB SSD
Nov 02, 2012 at 03:37 AM
Jon-Mark
p.1 #16 · OT: Help my LR 4.2 fly - whats in your box?
LR 4.2 runs beautifully for me. Windows 7 home built solution
Running Quad core i-7 Ivy Bridge 3770
Asus Sabretooth Z77 mobo
16GB OCZ 1600MHz DDR3 RAM
Running 7 drives in my tower, 3 of them SSD and 2x 24" monitors ( 1920x1200 ) off a Radeon HD 4870
Nov 03, 2012 at 12:08 AM
morganb4
p.1 #17 · OT: Help my LR 4.2 fly - whats in your box?
Can you please tell me a bit more detail about your ram?
Nov 03, 2012 at 07:44 AM
brett maxwell
p.1 #18 · OT: Help my LR 4.2 fly - whats in your box?
mine works great
BIOSTAR TZ68A+ motherboard
2500K at 4.4ghz
16gb (4 sticks) G.SKILL Ripjaws X Series DDR3 1600
OS on SSD
LR catalog/cache on other SSD
raw files on 1tb WD Caviar Black
Nov 03, 2012 at 04:11 PM
Manzelle
p.1 #19 · OT: Help my LR 4.2 fly - whats in your box?
ASRock Z77 Extreme4 Motherboard
Intel Core i7-3770S Ivy Bridge 3.1GHz @ 3.6GHz
Corsair Vengeance 32GB DDR3 @ 1866MHz
EVGA GeForce GTX 670
Corsair Force Series 3 120GB SSD
HGST Deskstar 7K3000 2TB @ 7200 RPM w/ 64MB Cache
Those are the vital guts and it laughs at everything I throw at it...so far.
Nov 03, 2012 at 05:00 PM
Jeff Simpson
p.1 #20 · OT: Help my LR 4.2 fly - whats in your box?
it flies
Intel Core i7 @ 5.0GHz
CORSAIR Hydro Series H60 High Performance Liquid CPU Cooler
GIGABYTE GA-Z68MA-D2H-B3
G.SKILL Ripjaws X Series 16GB
Kingston HyperX 120GB SATA III SSD
SAPPHIRE Radeon HD 6670 1GB 128-bit GDDR5
Apple 27" LED Cinema Display (via displayport)
https://www.facebook.com/media/set/?set=a.10101562637259325.3230612.12431374&type=1&l=085fc1c935
Nov 04, 2012 at 10:38 PM
