Ian.Dobinson Offline Upload & Sell: Off
p.1 #4 · Compact Flash connection to iPad | |
dmcly wrote:
Thanks! http://www.amazon.com/iPad1-Connection-Kit-Card-Reader/dp/B005NN8V3M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1351608933&sr=1-1&keywords=cf+card+reader+for+ipad
That was the one I tried , as I say it didn't like my ipad3 . I did try it on an iPad 2 but even then it was a bit iffy . Maybe it was a bad device.
This one may be a better option
http://www.amazon.com/Reader-Compact-Flash-Adapter-Apple/dp/B005D1IWHO/ref=pd_sim_e_4
Also there are a few things to remember with any cards via the camera connection kits (the apple SD version or the 3rd party ones)
1: the iPad will only see images within the DCIM folder (this can be used to your advantage as well )
2: the file names must be the standard length (7 characters I think). You can't have file names any other formt as the iPad won't see them.
3: the camera connection kit is one way traffic only. You can't save to the card from the iPad .
4: raw files are a pain on te iPad. They fill the pad up but the iPad only uses the embedded jpeg . (There is a raw converter app but its slower than usless) . But the worst thing I've found with raw files is that it can result in dead space . Im not sure if this is still current on the latest iOS but I have found previously when I deleted a whole bunch of raw files on te iPad I only recovered a little amount of MB . When I connected the iad to my pc I found I had a lot of memory that was listed as 'other' . I had to Basicly reset the iPad to recover the space .
5: shoot raw+jpeg and the iPad imports BOTH files and you can't seperate them .
I have eventually found some workarounds for some of te above
