Archive 2012 · Resource for Photoshop
RustyBug
p.1 #1 · Resource for Photoshop
I'd like to find a resource that can explain what the different functions of PS actually do numerically/mathematically.
For instance ... sliding the endpoints in levels adds/subtracts to the existing value.
Thanks
Oct 26, 2012 at 01:31 AM
mshi
[X]
p.1 #2 · Resource for Photoshop
Nothing beats Photoshop Online Help and Forums.
http://helpx.adobe.com/photoshop/topics.html
and you can download the PDF Help manual from there too.
http://helpx.adobe.com/pdf/photoshop_reference.pdf
Oct 26, 2012 at 03:52 AM
Mr Mouse
p.1 #3 · Resource for Photoshop
I do not think you are going the get that type of technical information from any Adobe publication, help or support. I have seen some web site with the math behind Photoshop's blending modes. I'm sure there is information on the web as to how image editing programs like Photoshop, Gimp and others do some of the adjustments the do. Try some web searches.
http://www.amazon.com/Algorithms-Image-Processing-Computer-Vision/dp/0471140562
Oct 26, 2012 at 08:44 AM
RustyBug
p.1 #4 · Resource for Photoshop
Thanks guys.
Yeah, I realize that I'm asking for a bit much ... but I recall some FM'ers (Peter comes to mind) having a technical dialogue @ how levels works mathematically. I realize that someone could do a "reverse engineer" study of each of the functions. I'm not looking for "everything" ... but the more I understand how / what something is going to do, the better I can incorporate it into the process.
As is, I do far too much iterative work, yet the straightforward methods don't yield the results I desire. For instance, I'm hoping to find a few clues so that I better know how to decide @ using levels vs. curves vs. exposure vs. contrast vs. USM vs. etc. They can all change the numbers, but they go about it from a different approach. While I have a visceral understanding of which to use when (developed through T&E) ... I'd like to change that from visceral to cerebral in some regard.
Just wondering if there is something out there that objectively/scientifically/mathematically explains the processes a bit more directly @ their underpinnings.
Oct 26, 2012 at 09:48 AM
AlphaValues
p.1 #5 · Resource for Photoshop
+1, I'd buy that book too.
Per discussion in another thread, I ordered a copy of Photoshop Channel Chops but it hasn't arrived yet. It's pretty old, but it was touted as explaining the architecture around the datasets (channels) in the image very well.
Oct 26, 2012 at 11:20 AM
RustyBug
p.1 #6 · Resource for Photoshop
Did you get the $4 one that I snoozed on ...
I've got one on the way as well.
Oct 26, 2012 at 11:51 AM
AlphaValues
p.1 #7 · Resource for Photoshop
I think I paid $10+s&H, that was the cheapest one when I went looking for it. Someone else must've seen the thread and beat me to it
Oct 26, 2012 at 12:40 PM
mshi
[X]
p.1 #8 · Resource for Photoshop
Layer bending math operations have been examined in Photoshop Channel Chops briefly but more importantly the book goes a long mile to discuss the Calculations command for manipulating alpha channels. Deke also has a title devoting entirely to blend modes. Dan Margulis has done an excellent video for Kelby titled There Are No Bad Originals, in which you will learn tons of insights: http://kelbytraining.com/course/margulis_no_bad_originals1/ . The take away from that title is you really need to do nothing is ACR and work with channels in Photoshop (by default Photoshop gives you ten channels for each image you open in Photoshop), if you desire to obtain the best possible images. By using either Calculations or Apply Image command, you can come up with unlimited number of alpha channels on the fly using those ten native channels.
Oct 26, 2012 at 01:49 PM
RustyBug
p.1 #9 · Resource for Photoshop
I set everything in ACR to "0" and mostly work from PS only (LR for some production oriented projects). The main thing I miss @ ACR in PS is color temp (i.e. 5500, etc.) numeric slider and more than 4 info point. But, I probably haven't strove to harness ACR to its max either.
+1 @ Dan Margulis & 10 channels. I'm comfortable with all, more @ RGB & LAB, not using CMYK nearly as often (since CMY is the inverse of RGB, K notwithstanding) using any of them via layers, but it's time to "raise the bar" @ refinement and go beyond my current comprehension / application.
Gee ... and it was only a couple years ago that I thought the saturation slider fixed everything.
At this rate, it'll be 2020 before I get "good". But, even though technology changes very rapidly and there are always new iterations around every corner ... color theory and value control is really the same as it has been for the last 10, 100, or 1,000 years, i.e. light & color don't change, only our tools for capturing & presenting them do. So, if it takes me another 10 years to get "command & control" of the tools ... I'll still have plenty of time to put them to good use.
Oct 26, 2012 at 02:26 PM
mshi
[X]
p.1 #10 · Resource for Photoshop
K in CMYK can be used to do some amazing stuff in a RGB image. For example, K can be used to bring back lost shadow details or can be used to desaturate shadows on the fly.
Oct 26, 2012 at 02:39 PM
RustyBug
p.1 #11 · Resource for Photoshop
I've done some sharpening on K ... but hmmm @ desat shadows. That could be interesting shadow color cast ... do tell.
Oct 26, 2012 at 03:21 PM
mshi
[X]
p.1 #12 · Resource for Photoshop
Desat using whatever the tool you feel like in RGB and add an inverted K as the mask. Blur the mask using the mask properties to get that seamless effects. That's it.
Oct 26, 2012 at 04:07 PM
RustyBug
p.1 #13 · Resource for Photoshop
Will have to give it a go ... thanks.
Oct 26, 2012 at 04:22 PM
Wayne Willison
p.1 #14 · Resource for Photoshop
Can you give us an example? How do you segregate K to work with it?
Wayne
Oct 28, 2012 at 11:26 AM
mshi
[X]
p.1 #15 · Resource for Photoshop
Wayne
There are many different ways to achieve that. One simple way to do is to create different COLOR modes. You can use Duplicate command under Image menu to make a copy of your image opened in RGB,
http://24.media.tumblr.com/tumblr_mcm6ro4zhe1rvtmuto1_1280.jpg
and then use CMYK Color command under Image->Mode menu to covert the RGB image to a CMYK image.
http://24.media.tumblr.com/tumblr_mcm6ro4zhe1rvtmuto2_1280.jpg
Now you have two identical image open in Photoshop, one in RGB Color, the other in CMYK Color.
Back in the RGB image, put a desaturation adjustment layer using whatever tool you like, such as using Vibrance Adjustment Layer. Desat the image by playing with two sliders, then click on the white mask.
http://25.media.tumblr.com/tumblr_mcm6ro4zhe1rvtmuto3_1280.jpg
Now use Apply Image command under Image menu,
http://25.media.tumblr.com/tumblr_mcm6ro4zhe1rvtmuto4_1280.jpg
in the opening dialog box, select the CMYK doc from Layer, select Black from Channel, click the Invert box, and select Normal from Blending.
http://24.media.tumblr.com/tumblr_mcm6ro4zhe1rvtmuto5_1280.jpg
http://25.media.tumblr.com/tumblr_mcm6ro4zhe1rvtmuto6_1280.jpg
You just added an inverted K channel as the mask for Vibrance Adjustment Layer in RGB. Now double click on the mask to open up its Properties tag, and drag the Feather slider to the right, somewhere around 100 px, to soften the effects.
http://24.media.tumblr.com/tumblr_mcm6ro4zhe1rvtmuto7_1280.jpg
Oct 28, 2012 at 12:27 PM
Wayne Willison
p.1 #16 · Resource for Photoshop
Mshi, thanks for the well done walkthrough. I followed each step as you laid out, but I can't see the advantage of doing this when I can easily open the shadows in ACR.
Am I missing something?
Wayne
Oct 28, 2012 at 02:53 PM
mshi
[X]
p.1 #17 · Resource for Photoshop
Wayne
Yes, you can use ACR to bring up shadow details too. There are differences in results.
Oct 28, 2012 at 04:51 PM
RustyBug
p.1 #18 · Resource for Photoshop
@ Pg 150 of PCC
e.g. Multiply =
Pixel A * Pixel B / 256
128 * 128 / 256 = 64
.5 * .5 = .25
Includes a few others as well.
Shame it doesn't have more, but it is good to see the few that it does have.
Nov 03, 2012 at 09:28 PM
Peter Figen
p.1 #19 · Resource for Photoshop
The early versions of Real World Photoshop also had basic descriptions of the math behind many of the blending modes. Of course, I haven't looked at those in many years.
Nov 03, 2012 at 10:53 PM
RustyBug
p.1 #20 · Resource for Photoshop
Thanks Peter.
I realize that most people won't want such numerical madness, but I find it helpful ... for some things.
Nov 03, 2012 at 11:38 PM
