       2       3       end
85L vs 135L for Engagement Shoots
ZachOly
p.1 #1 · 85L vs 135L for Engagement Shoots
I'm an engagement photog with a 35L and 135L. The combo is ok, but I find the 135 a little long for full body shots.
I know that the 85 1.8 is cheap, but I'd like to stick with L glass, if for nothing else than the fact that I have several 72mm filters.
Anyone switch from the 135 to an 85L? Thoughts? Recommendations?
Oct 25, 2012 at 04:28 PM
samwise
p.1 #2 · 85L vs 135L for Engagement Shoots
They are both very good and I use them both, I would say the 85L gets used more though and I would be lost without it... so that would be the one to choose if you had to choose.
Hard to beat the butter the 135L produces however, if you can step back enough you can do pretty much anything with it, I would never sell mine because of how much its used during weddings (ceremonies/receptions)
PS - I have never heard of an "engagement photog", interesting
Oct 25, 2012 at 05:04 PM
Daan B
p.1 #3 · 85L vs 135L for Engagement Shoots
I would switch the 135L for a 70-200 2.8 II IS. Makes a great combo with the 35L for this type of shooting.
Oct 25, 2012 at 09:03 PM
coibeo2610
p.1 #4 · 85L vs 135L for Engagement Shoots
This is exactly what I'm thinking.
35L + 70-200 II are very nice combos for such shooting purpose.
Best,
MC
Oct 26, 2012 at 06:21 AM
Rav13
p.1 #5 · 85L vs 135L for Engagement Shoots
I've got both and also the 70-200L II, the 85L and 135L is an excellent combo but I use either one and a 35L, i don't think I could use both for an event together. The 85L gets the most use, that lens is one amazing lens, I love the images I get from it.
Oct 26, 2012 at 09:23 AM
PhilDrinkwater
p.1 #6 · 85L vs 135L for Engagement Shoots
I use the 135 and weddings and it does produce beautiful results - some of my favourite shots. However, I would gladly use a 70-200 except it's just too heavy for me for "hours".
If you can cope with the weight I'd get a 70-200..
Oct 26, 2012 at 09:41 AM
Sneakyracer
p.1 #7 · 85L vs 135L for Engagement Shoots
Honestly I would not go to a shoot like that without the 70-200mm f2.8L IS II (or I). Its an awesome lens, versatile and has IS which is a very invaluable when shooting handheld out and about with long focal lengths. At one point I also added the 85L and loved it, has a unique look when used at f1.2~f2, but the AF was just too slow and not as consistent as the 70-200 so I sold the 85L since I used it very little. Its at its best in posed static shot situations. I found the 135L too long of a focal length to make do without IS.
So in short. The 70-200 is a must have. You can add lenses later but that one is a must in the bag.
Oct 26, 2012 at 12:32 PM
splathrop
p.1 #8 · 85L vs 135L for Engagement Shoots
If you have enough light to shoot the 135L at f/2.0, it will notably outperform the 70-200 IS II (at 135mm) on bokeh. And it will notably outperform the 85L on subject sharpness, focusing speed, and focusing accuracy, while giving up maybe just a smidge on bokeh. The 135 L is advantageous for candids, too, because you work from a greater distance with a smaller black lens that doesn't draw the subjects' attention as readily as the 70-200. The 135 L is a hard lens to give up. I can see wanting the 70-200, but not substituting it for the 135 L. You ought to have both. If you do, you don't need the 85L.
Oct 27, 2012 at 10:43 AM
cobra0469
p.1 #9 · 85L vs 135L for Engagement Shoots
I'd keep both the 35L and 135L, and would add the 70-200 II because of versatility. The 85L and 135L both produce excellent images, was a matter of focal length and focusing speed that made me choose the 135L over the 85L. I've also owned the 70-200II and agree it is an excellent lens, but it doesn't replace the 85L or 135L in any form except focal length. The size was my biggest dislike.
I'm an amateur that does not shoot for hire, if I were the 70-200II would be in my bag because of the versatility and quality. I would buy the 85L if I had a need for the best 85mm lens available, and had the cash.
Oct 27, 2012 at 04:17 PM
jrscls
p.1 #10 · 85L vs 135L for Engagement Shoots
I have the 35 L, 85 L II and 70-200 MK II. I prefer the 85 L II for portraits, including e-sessions. I also posted this one on POTN, taken wide open at f/1.2 with 85 L II on full frame-
Oct 27, 2012 at 06:13 PM
chris78cpr
p.1 #11 · 85L vs 135L for Engagement Shoots
85L is just such a versatile lens for wedding, engagement, portrait and people shooting. I use a combo of 24/50/85 for my work. I have access to the 135 and have only found it needed on one or two occasions.
Oct 27, 2012 at 06:43 PM
zeljkito
p.1 #12 · 85L vs 135L for Engagement Shoots
Hi,
I own both and have to admit that 135 gets much less mileage. As much as it really depends on the situation and scenography, I would say it is 75% 85L. And as hurtful as it is, I am even considering selling 135 since I own 70-200/2.8. But it all depends on your shooting style (my135 is much faster in AF terms)
Oct 31, 2012 at 11:15 AM
dmcharg
p.1 #13 · 85L vs 135L for Engagement Shoots
I used to own the 35L, 85 1.8 and 135 F2L. Of the three the 135 is the one lens that really stands out, the color, contrast and sharpness at F2 is simply amazing. Having said this i found the 135 was a strange focal length so it just didn't get used enough so i ended up selling it. The 85 1.8 is a cracking little lens and you can save yourself a serious amount of money buying the 85 1.8 and filter vs the 85 1.2L. If your going to use F1.2L a lot then get the 85L but otherwise the 85 1.8 is a cracking little lens and a much better focal length than 135. I tried the 85L and it takes some getting used to in order to get shots at F1.2 as the depth of field is very thin, if you end up stopping down all the time to get enough dof with a couple then i see no advantage in having the 85 1.2L. I ended up selling my primes and moving to the 2.8 zooms as i found F2.8 offered enough subject isolation whilst still having a reasonable depth of field. The 85L really is a speciality lens so if you use F1.2 all the time its worth it, when i reviewed thousands of pics taken with my primes i found i was stopping down a lot so F2.8 was good enough my needs so the 2.8 zooms made much more sense.
Edited on Oct 31, 2012 at 12:23 PM · View previous versions
Oct 31, 2012 at 12:00 PM
zeljkito
p.1 #14 · 85L vs 135L for Engagement Shoots
I second that - That is exactly why I kept both, 85/1.2 and 85/1.8. Much faster focusing and almost as sharp as the L. Bokeh is a bit more "nervous", but for that price, selling it would be a blasphemy :-)
dmcharg wrote:
I used to own the 35L, 85 1.8 and 135 F2L. Of the three the 135 is the one lens that really stood out, the color, contrast and sharpness at F2 is simply amazing. Having said this i found the 135 was a strange focal length so it just didn't get used enough so i ended up selling it. The 85 1.8 is a cracking little lens and you can save yourself a serious amount of money buying the 85 1.8 and filter vs the 85 1.2L. If your going to use F1.2L a lot then get the 85L but otherwise the 85 1.8 is a cracking little lens and a much better focal length than 135. I tried the 85L and it takes some getting used to in order to get shots at F1.2 as the depth of field is very thin. I ended up selling my primes and moving to the 2.8 zooms as i found F2.8 offered enough subject isolation whilst still having a reasonable depth of field.
Oct 31, 2012 at 12:10 PM
chris78cpr
p.1 #15 · 85L vs 135L for Engagement Shoots
I sold my 85 F1.8 and have not regretted it at all yet.
Oct 31, 2012 at 01:23 PM
RichardLavigne
p.1 #16 · 85L vs 135L for Engagement Shoots
IMO... you really can't compare these two lenses.. as they are different focal lengths that give different effects. It really depends on the purpose of the shot and the look you're trying to go after.
Here is a recent engagement session we did... used 16-35L, 35L, 50L, 85L, 100L macro, 135L and 135L w/ 1.4 tc.
Oct 31, 2012 at 03:24 PM
Peacekpr
p.1 #17 · 85L vs 135L for Engagement Shoots
I think it just comes down to personal preference. I have the 70-200 2.8 L IS Mk 2 and the 85L. Both are incredible lenses. Add in the new 24-70L Mk2 and there's nothing you can't do in portraits or weddings.
Oct 31, 2012 at 05:10 PM
Ghost
p.1 #18 · 85L vs 135L for Engagement Shoots
Both are 2 of 3 in the Canon Trinity. Both are extremely good lenses. AF is quick on the 135L. If you need f1.2 there's no substitute.... well a 50L on a cropped cam might I supposed.
If you have the space, the 135L produces some of the most amazing images I've ever seen. Even a mundane battery photo can be made magical by this lens.
Oct 31, 2012 at 06:50 PM
chris78cpr
p.1 #19 · 85L vs 135L for Engagement Shoots
Great set of images, but i think you could get a similar set of shots using just a couple of lenses.
Nov 01, 2012 at 03:02 PM
Mike Mahoney
p.1 #20 · 85L vs 135L for Engagement Shoots
I have both mentioned (85 & 135) and my most-often used portrait length is 85mm on a APS-H body (1 series) which has a 1.3 multiplier, making the 85 about 110mm. This for me is perfect.
I find an 85 on FF slightly to short, and I find a 135 on FF slightly too long, and entirely too long on any crop body. But an 85 on a 1.3 crop sits just right for me.
Everyone is different .. some wedding & couples shooters prefer to shoot with longer lenses and capture any undirected interaction between the couple as it unfolds, others prefer to be a bit closer and offer some direction or do some posing with them. So as always focal length choice is usually a matter of personal style & preference.
Nov 01, 2012 at 03:59 PM
       2       3       end
       2       3       end
