p.1 #1 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
I bought a 50/1.2 and am having focus issues that haven't resolved even after micro-adjusting with Reikan FoCal. I sent my 5DIII (which I purchased in May of this year) along with the 50/1.2 for adjustment. I just got an email invoice for $284.
I was under the impression that this would be covered under warranty. Is that not the case? I will call them tomorrow (they're closed now), but wanted to check here first.
UPDATE: apparently they misplaced my sales receipt for the 50/1.2, which is why they were charging me for the repair (they didn't have evidence it was under warranty.) As soon as I faxed them the receipt, they zeroed the invoice and performed the repairs for free. They did an excellent job and turned it around in less than 48 hours. I'm very happy with their service.
p.1 #10 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
I had all my lenses calibrated to my two 5DIII's and there was no charge the reason I left all my lenses was because the lady told me since the body was still under warranty there would be no charge.
p.1 #14 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
Lens and body should be covered under warranty. The question now is why 5D3 re-calibratted when it is doing well with your 85L and 35L. Make sure you test them all again. This reminds us lot of folks complain about 50L while their 85L and 35L doing well. What did they do to your 5D3 ...AF sensor adjustment
p.1 #15 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
I just sent in my 5D3 and my new 35L for calibration a month ago and there was no charge
I called first because it was my first time sending something in and they said to be sure to include copies of the receipts so they could verify that both were under warranty.
p.1 #16 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
I was under the impression that Canon would micro-adjust or calibrate my 5D3 to the 50/1.2, and that wouldn't affect how my other lenses focus. Is that not the case?
p.1 #17 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
p.1 #18 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
If you calibrate a body to a lens then you cannot be sure that other lenses will not be affected.
The body should be checked as within specification and the lens checked separately - then they should work together (as should any other lenses and/or bodies you have, in any combination).
p.1 #19 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
Just talked to Canon. They didn't see the receipt I sent for the 50/1.2, which is why they were trying to charge me.
I've heard of others who had trouble micro-adjusting the 50/1.2, and they said they sent it into Canon with their body and it came back spot on. Nobody mentioned it affecting their other lenses, so I hope it doesn't for me either.
p.1 #20 · CPS charges $284 to calibrate a lens to a 5D III body? (UPDATED)
I had always thought that they would provide adjustment free of charge as long as EITHER the camera or the lens is still under warranty. Basically, I thought, say, if I bought a lens and it didn't work well with my camera, Canon would ask me to send the lens along with the camera(s) that I used for free adjustment.
