Archive 2012 · Can someone explain?
BigIronCruiser
p.1 #1 · Can someone explain?
I have a D800, D4, Nikkor 24-70 2.8 and Nikkor 70-200 2.8. A studio light was pointed at a white background that meters f/8 at 1/250 and ISO400 with a Sekonic L-508. Both bodies were set to manual, ISO400, f/8 and 1/250, and both lenses are set to 70mm. One would reasonably expect the exposures to be identical with both lenses, but the 24-70 comes out slightly more than 1/3 stop underexposed on both bodies. The difference can be seen on the LCD, and it's confirmed by the histograms. Explanation?
Oct 18, 2012 at 03:15 PM
tomrock
p.1 #2 · Can someone explain?
The world isn't perfect?
I've noticed color differences between my 24-70 and 85. Same type of thing, I think.
Oct 18, 2012 at 03:22 PM
Frank_Maiello
p.1 #3 · Can someone explain?
Read up on F-stops vs. T-stops. Wikipedia has a good explanation.
http://en.wikipedia.org/wiki/Tstop#T-stop
Oct 18, 2012 at 03:24 PM
woos
p.1 #4 · Can someone explain?
Aperture blades aren't always absolutely perfectly calibrated. T-stops, as well (though doesn't the 24-70mm have a higher t-stop than the 70-200?).
Oct 18, 2012 at 03:28 PM
BigIronCruiser
p.1 #5 · Can someone explain?
Thanks. Now it makes perfectly (?) good sense, and it's easy enough to pick up with the histograms. The 1/3 stop difference between the Nikkor's isn't a big deal, but I imagine it could be much more unpredictable with cheap glass.
Oct 18, 2012 at 04:01 PM
Waki
p.1 #6 · Can someone explain?
It's probably not the glass. Shutter speeds for any camera are never exact. You might pick 1/250 but you may vry well be getting 1/200. There was something published about actual versus selected shutter speeds and ISO settings. Being off by a third stop between cameras is pretty good to me.
Oct 18, 2012 at 04:10 PM
tomrock
p.1 #7 · Can someone explain?
Shutter speed doesn't have anything to do with strobe exposure.
Oct 18, 2012 at 04:22 PM
Gregstx
p.1 #8 · Can someone explain?
I have noticed that my Sigma 50 mm, f1.4 lens tends to overexpose at larger apertures when compared to my other lenses.
Oct 18, 2012 at 05:06 PM
Andre Labonte
p.1 #9 · Can someone explain?
Not completely true but true enough for most practical situations.
Oct 18, 2012 at 07:01 PM
