What are the criteria?
B/W Church
Oregon Gal
p.1 #1 · B/W Church
A one image shot, no HDR taken last week while on a return trip to the area. I may crop in some on the left hand side. Let me know if you have any suggestions for improvement.
Oct 15, 2012 at 01:05 PM
Bob Jarman
p.1 #2 · B/W Church
Very nice - especially the sky and soft lighting on the church. Contrast fits the mood well.
Nit: distortion - trees and steeple are not vertical.
Regards,
Bob
Oct 15, 2012 at 01:17 PM
Oregon Gal
p.1 #3 · B/W Church
A couple more tweaks are required and thanks for mentioning the distortion. I should never try to work on images in the middle of the night I think I should go and lighten the top of the steeple as well while I am at it.
Oct 15, 2012 at 01:21 PM
sbeme
p.1 #4 · B/W Church
Barbara,
I really like this image.
Love the contrast, dark mood, and the dark clouds on the left add both visual balance and mood to a fine image. Comp is spot on in my opinion.
Bob and others may have more useful fine tuning suggestions than I can offer.
Tweak, cross-post to BW.
Scott
Oct 15, 2012 at 01:40 PM
RustyBug
p.1 #5 · B/W Church
Diggin' the tones.
Also, the alignment of the window that lets you "see through" is a nice detail. +1 at above posts.
I might consider trimming some off the bottom, still leaving enough to bring the shadow line "near" the LLC. Also, I might consider cloning the tree branch in the URC ... noting that I said consider for both as we are only talking subtle points
Nicely done.
Oct 15, 2012 at 03:11 PM
Oregon Gal
p.1 #6 · B/W Church
Scott, glad you like the image. The posted version is a little flat so I did some additional straightening of the tree, Church steeple and lightened the top of the church. I may post a couple images over in the B/W forum, thank you for suggesting it.
Kent, appreciate your comments and I cropped out the uppermost limp on the right but not sure if I like it, it's on a separate layer so I can replace the limb at a moment's notice. I haven't played around with cropping tighter on the bottom so I will look into that. Thanks, Barbara
Posted a re-work with the suggested corrections.
Oct 16, 2012 at 02:43 AM
RustyBug
p.1 #7 · B/W Church
Don't change another thing, your tweaks are sweet.
Oct 16, 2012 at 03:56 AM
Oregon Gal
p.1 #8 · B/W Church
Kent, I still see a couple of more things I want to do but I won't show you
Oct 16, 2012 at 05:08 AM
AuntiPode
p.1 #9 · B/W Church
Or with a slightly different set of tweaks....
Oct 16, 2012 at 06:01 AM
Oregon Gal
p.1 #10 · B/W Church
Thank you Karen for presenting an alternate version. Always enlightening to see your re-works and hear your suggestions.
Oct 17, 2012 at 04:40 AM
