Archive 2012 · 5DIII wifi really $800?
bbasiaga
p.1 #1 · 5DIII wifi really $800?
I did a search but it returned zero results. So sorry if this has come up before but...
Does it really cost that much money to add Wifi to the 5dIII? I found the canon WFT-E7A for $839....
I thought I heard people saying the adapter was $250. Do I have the wrong thing? If not...that feature on the 6D is a complete steal!
-Brian
Oct 12, 2012 at 10:04 PM
dmahar
p.1 #2 · 5DIII wifi really $800?
Brian just use an eyefi sd card. It provides wireless file transfer from your 5diii to a computer, iPad, phone etc. All for about $99.
Cheers
Doug
Oct 12, 2012 at 10:10 PM
JohnBrose
p.1 #3 · 5DIII wifi really $800?
eyefi requires internet I believe. I don't know if the Canon equipement does. There is probably a speed difference also. I've used the eyefi card for about a month and it's fairly slow to upload the files.
Oct 12, 2012 at 10:36 PM
dmahar
p.1 #4 · 5DIII wifi really $800?
John
My eyefi pro does not require Internet access it talks directly to the target device (eg) iPad via WiFi. I agree it is not super fast.
Cheers
Doug
Oct 12, 2012 at 10:45 PM
StillFingerz
p.1 #5 · 5DIII wifi really $800?
Read the specs for the 5D3's wifi and I doubt the 6D will come close. The separate wifi unit is a/b/g/n compliant, bluetooth ready, ethernet wifi and wired ready...it's basically a mini router. You can't fit that much tech in the smaller body or above the prism....at least not yet.
I'd be surprised if the 6D gives us n level, maybe not even g level wifi...it's specs aren't fully explained yet that I'm aware of. wifi is not built in to the 5D3 due to it's total mag body, the top of the 6D is polycarb.
Edited on Oct 12, 2012 at 10:51 PM · View previous versions
Oct 12, 2012 at 10:50 PM
JohnBrose
p.1 #6 · 5DIII wifi really $800?
yes, via wifi, but if that ipad doesn't have wifi/internet, I don't believe it will work. I may be wrong, but that's my understanding.
andyz
p.1 #7 · 5DIII wifi really $800?
I have a WiFi attachment for my 1D Mark III and with ShutterSnitch on my iPad I can broadcast directly to it.
Oct 12, 2012 at 10:52 PM
skibum5
p.1 #8 · 5DIII wifi really $800?
It does. You can be 30 miles deep into the woods and have the ipad cellular service turned off and EyeFi Card can still beam to the ipad.
Oct 12, 2012 at 10:55 PM
skibum5
p.1 #9 · 5DIII wifi really $800?
And yeah the wifi gripper for the 5D3 is absurdly over-priced. Not even a fancy router costs even a fraction of $800.
Oct 12, 2012 at 10:56 PM
StillFingerz
p.1 #10 · 5DIII wifi really $800?
There are 2 types of communications, router based like in your home; your cable tv/internet device and what's called broadband which is supported via cell towers, like your smartphone is.
If your device, like a lower level kindle; the 1st Fire for instance, only has wifi, then you can only play content that has been installed or downloaded directly to the devise via a wifi router; your home, starbucks, an airport, etc. If it has broadband, like 3G, then the devise can receive live streams of data as long as you are within a cell towers range.
One requires a data plan, 3G, etc... from your phone company
Hope this helps...
Jerry
Oct 12, 2012 at 11:06 PM
dwweiche
p.1 #11 · 5DIII wifi really $800?
StillFingerz wrote:
Read the 5D3's wifi and I doubt the 6 will come close. The separate wifi unit is a/b/g/n compliant, bluetooth ready, ethernet wifi and wired ready...it's basically a mini router. You can't fit that much tech in the smaller body or above the prism....at least not yet.
802.11 b/g/n dual band solutions from several vendors are highly integrated and relatively cheap. I would suspect it will be b/g/n compliant. If I were to predict further, I would say it is probably going to be dual band, too. That is "table stakes" these days.
Oct 12, 2012 at 11:48 PM
StillFingerz
p.1 #12 · 5DIII wifi really $800?
I hope you're right, but dual band...I'd say not, not in a low end model?
Oct 13, 2012 at 12:02 AM
Ian.Dobinson
p.1 #13 · 5DIII wifi really $800?
All iPads ARE wifi . And some are cellular .
On the basis that the eyefi card or the canon wireless grips are not cellular , then your just using the wifi coms of the iPad so all iPads will be fine.
There are obviously advantages to the wifi grips (or the plug in ones of the 1 series) but they are stupidly expensive .
Canon are most likely pricing them on the basis that most buyers of a device like it would be pro's that shoot events and need to send high volumes of data . And without there being another cheaper solution (that's as fast and reliable) they just HAVE to buy it.
Oct 13, 2012 at 02:29 AM
