FM Actions & Plugins support
Workflow Guidelines
LR+1D4+ 24-70mm II saving images in 600KB Jpg
anil007
p.1 #1 · LR+1D4+ 24-70mm II saving images in 600KB Jpg
I was trying to save some pictures taken with 1D4 and 24-70 II in LR to small jpegs(600KB) and I got error saying it can not save that small, was wondering if anyone else experienced the same? Or it's just that I am doing something wrong.
Thanks for any pointers.
Oct 12, 2012 at 01:35 PM
mmurph
p.1 #2 · LR+1D4+ 24-70mm II saving images in 600KB Jpg
That does not make sense. I Export JPG's at 50K all of the time.
LR4? Are you using Export?
There is a setting box for minimum size by pixels, both horizontal & vertical. Perhaps you have a pixel width entered as 2, 3, 5, .1, etc. I know you can use sizes as small as 150x200 pixels, as I did that recently.
Some other setting though is not correct. There is also a "Pixels Per Inch" component of the pixel size, that defaults to 72. Or you can also specify as in or cm.
I tried the "Megapixels" setting size. that will not go below "1."
That is what you get for selling lenses for too much money! (joke.)
Interesting to see that it went to Western Michigan. I am near Ann arbor.
Best,
Michael
Oct 13, 2012 at 02:36 AM
WAYCOOL
p.1 #3 · LR+1D4+ 24-70mm II saving images in 600KB Jpg
I suspect you have to reduce the dimensions to get such a small file size.
Oct 13, 2012 at 05:13 AM
anil007
p.1 #4 · LR+1D4+ 24-70mm II saving images in 600KB Jpg
thank you Michael and Doug. reducing size solved the problem. I will try to keep prices down
Oct 13, 2012 at 12:19 PM
Mike M. Kraus
p.1 #5 · LR+1D4+ 24-70mm II saving images in 600KB Jpg
Wish you had done that just a little sooner
Oct 13, 2012 at 06:47 PM
mmurph
p.1 #6 · LR+1D4+ 24-70mm II saving images in 600KB Jpg
As Nikon taught us, bigger MP is better = More Money!
(or less ... D800 is less than 5D3 ... hmm ..36MP/22MP = $3,500/$3,000 = 3/2* $3,500 = $6,800 = 18MP 1DX is $6,800... 36/18 = 2*3,500 = $7,000..... bad math skills ... add, carry ... divide by zero error ...)
I iz an attiste, f* it!
Cheers!
Michael
Oct 14, 2012 at 03:18 AM
