Archive 2012 · Flash Question
rprouty
p.1 #1 · Flash Question
Any reason to replace/upgrade from a Canon 580EX II to the new 600 if I only use flash on camera or on a bracket? Thanks
Rod
Oct 11, 2012 at 01:54 PM
Dragonfire
p.1 #2 · Flash Question
Recycle time is probally your only advantage.
Oct 11, 2012 at 02:33 PM
p.1 #3 · Flash Question
The 600EX-RT has an AF assist pattern that matches the 1DX and 5DIII AF sensor matrix. I found it's better (i.e. faster) in low light on my 1DX than a 580EX or 580EX II. So, if you're likely to shoot low light events with your 5DIII (or you get a 1DX), then it might be worthwhile. Otherwise, maybe not. Also, the 600EX-RT has a longer max. focal length of 200mm. This might be a plus for long lens shooting without a Better Beamer, but I haven't tried it yet.
Oct 11, 2012 at 02:38 PM
CW100
p.1 #4 · Flash Question
Rod
like others have said, there are a couple of advantages but not much if just leave the flash on the camera
Oct 12, 2012 at 05:58 AM
