Archive 2012 · Owachomo - wide, wider, widest
Camperjim
p.1 #1 · p.1 #1 · Owachomo - wide, wider, widest
I am interested mainly in opinions about the compositions of these images. I have wide, wider and even wider images and then an image that required an ultrawide lens and panorama stitching. At this point I am still trying to decide on the composition. I haven't thought much about processing and these were done quickly. I know I need to spend some more thought and time on better processing.
Owachomo - Wide
Wider
Widest
Pano Wide
Oct 09, 2012 at 04:35 AM
AuntiPode
p.1 #2 · p.1 #2 · Owachomo - wide, wider, widest
The arch is bigger in the first - a good element, but the composition seems awkward. The composition of the second is better, but could probably be strengthened with a careful crop. The third is OK but not as strong as the second. The pano is the strongest because the pool and the arch share a visual motif, but it would also benefit from a crop to emphasize the visual echo of the arch in the pool:
Oct 09, 2012 at 06:27 AM
ben egbert
p.1 #3 · p.1 #3 · Owachomo - wide, wider, widest
2nd is my favorite, probably because I dislike squarish images.
But the pano does get all the pool which I like. Karens crop is better, but maybe even more.
Oct 09, 2012 at 02:48 PM
sbeme
p.1 #4 · p.1 #4 · Owachomo - wide, wider, widest
Pretty much in agreement with Karen, except that I prefer 3 over 2.
As Karen pointed out, a strong compositional element is the successful echoing of shapes in the foreground pool and distant arch.
Scott
Oct 09, 2012 at 02:55 PM
Camperjim
p.1 #5 · p.1 #5 · Owachomo - wide, wider, widest
Thanks for the input.
I often find it difficult to be objective especially for images like these where setting up a composition was difficult because of the rough ground and dropoffs.
I like image #1 because it was the most realistic and the bridge was of reasonable size. #2 I like because of the curving line. It seems that #4 is the most liked image. I do like the composition but have some difficulty because the wide angle has caused such distortions. The foreground appears to be a small stream pouring into a small lake. Actually the foreground stream was nothing more than a very small trickle of water. With the help of an ultra wide lens and panorama stitching I may have created an interesting composition, but it is very poor in representing the actual scene.
Oct 10, 2012 at 03:51 AM
HiredGoon
p.1 #6 · p.1 #6 · Owachomo - wide, wider, widest
Nice images. I think I prefer the pano shot.
I was there on new years day, and the creek was frozen. And I was back there in June, and the creek was completely dry. So no reflections either time that I went, unfortunately.
Oct 10, 2012 at 07:00 AM
silvawispa
p.1 #7 · p.1 #7 · Owachomo - wide, wider, widest
Odd because it's the pano that is the image that transports me there most. For me it conveys the best 'sense of place'. I don't know whether this is despite or because of the distortions.
(I hadn't even noticed the stream coming in until you'd mentioned it!)
Oct 10, 2012 at 02:38 PM
Camperjim
p.1 #8 · p.1 #8 · Owachomo - wide, wider, widest
I guess I was lucky. This is an image from the second week of June 2012. It was just short of 100 degrees and had not rained since who knows when. I was also lucky enough to also get water reflections for Sipapu and Kachina.
Oct 10, 2012 at 02:56 PM
