Archive 2012 · Narrowed it down to One Einstein or 2 b800s ???
rennocneb
p.1 #1 · Narrowed it down to One Einstein or 2 b800s ???
Just as the title says ive narrowed my choices down to either one einstein or two b800's with the vagabond mini, stands and softboxes probably, and a beauty dish. Portability is important and power for outdoor high light work, but i dont want to totally give up my felxibility will i using the single einstein?
Sep 26, 2012 at 07:15 AM
cordellwillis
p.1 #2 · Narrowed it down to One Einstein or 2 b800s ???
What is the question?
Sep 26, 2012 at 08:03 AM
rennocneb
p.1 #3 · Narrowed it down to One Einstein or 2 b800s ???
i guess how much am i giving up having only one light available right now? i plan to add later as funds allow and i do have a single sb700 speedlight available if that would help at all?
Sep 26, 2012 at 08:05 AM
RustyBug
p.1 #4 · Narrowed it down to One Einstein or 2 b800s ???
Einstein + B400 if funds are tight.
The second light will come in handy, but the Einstein will likely be your workhorse. You'll be able to use your speedlight as your second (or third) light, but with the SB / BD the Einstein will prove its value. Having the B400 will obviously not be the power of the Einstein, but the flexibility of using your modifiers on either will afford a mix and match flexible system. Add additional lights as needed later ... the B400 still serves well as bg/hair/kicker/fill, so you've not lost anything (and the B400 is lighter).
Sep 26, 2012 at 08:20 AM
rennocneb
p.1 #5 · Narrowed it down to One Einstein or 2 b800s ???
im planning to add a second soon, as in a couple weeks after getting some other startup costs taken care of. i just have a couple of senior photo shoots at west baden springs hotel which is a historic venue around here, that im wandering if a single einstein with a big softbox would do the shoot.
Sep 26, 2012 at 09:17 AM
kenyee
p.1 #6 · Narrowed it down to One Einstein or 2 b800s ???
get the Einstein and use your SB700 in the meantime.
Look up Zach Arias to see what you can do w/ "only" one light...
Sep 26, 2012 at 09:20 AM
rennocneb
p.1 #7 · Narrowed it down to One Einstein or 2 b800s ???
another nagging question, they say the ab1600 might be to much for a normal room? if it had a softbox on it is that truly the case?
Sep 26, 2012 at 09:37 AM
sic0048
p.1 #8 · Narrowed it down to One Einstein or 2 b800s ???
A AB1600 won't go down to really low power. I could see it easily overpowering a small or normal size room. The ABs have three different models all based with different power levels. The AB400 is the lowest power, the AB800 is mid range, and the AB1600 is high power. The real beauty of the Einsteins is the fact that they have very good power control and basically cover the entire range of all three ABs (from very low power to very high power) all in the same unit. That along with the much better color control make the Einsteins much more attractive IMHO.
Sep 26, 2012 at 10:17 AM
rennocneb
p.1 #9 · Narrowed it down to One Einstein or 2 b800s ???
which modifers would you all recommend with a single einstein?
Sep 26, 2012 at 10:36 AM
Deezie
p.1 #10 · Narrowed it down to One Einstein or 2 b800s ???
If you're going to be shooting outdoors I would recommend a beauty dish. If you're inside, I would suggest a large soft box. Be nice to have both. But it really depends on what you're shooting.
Sep 26, 2012 at 10:41 AM
PeterBerressem
p.1 #11 · Narrowed it down to One Einstein or 2 b800s ???
Especially on a low budget the PLM is a viable softbox substitute when you add a front diffusor (e.g. 64" total $ 75).
Sep 26, 2012 at 10:50 AM
jolson72
p.1 #12 · Narrowed it down to One Einstein or 2 b800s ???
I currrently have 2 einsteins and 3 older White Lightning Ultra Zaps. If I was just starting, I would save my money and purchase an Einstein. One advantage is the wireless triggers specifically designed for the Einstein. Very small, inexpensive, simple to use.
And, I like the build quality of the Einstein and the older White lightning Ultra flash units over the Alienbees.
Sep 26, 2012 at 10:53 AM
rennocneb
p.1 #13 · Narrowed it down to One Einstein or 2 b800s ???
which beauty dish do you guys recommend?
Sep 26, 2012 at 11:02 AM
sleibrand
p.1 #14 · Narrowed it down to One Einstein or 2 b800s ???
I'd also vote for the Einsteins. The additional flexibility in the power ranges compared to the AB's is really nice as is the remote controls.
I really like the PLM's but not sure how suitable they'd be for you. If you have very little wind, they could be nice.
Sep 26, 2012 at 11:23 AM
Dave Jr
p.1 #15 · Narrowed it down to One Einstein or 2 b800s ???
I have Einsteins but am considering adding an AB1600 for outdoor use (Senior Portrait shoots) because of the long flash duration, allowing Supersync with Yongnuo 622c transceivers.
Sep 26, 2012 at 11:44 AM
Dave Jr
p.1 #16 · Narrowed it down to One Einstein or 2 b800s ???
The 35" PCB Folding Octa is a popular choice for outdoor use.
I am not a fan of the PCB Beauty dish, but it is cheap. If you want a better dish, take a look at the Kacey 22" BD.
Sep 26, 2012 at 11:47 AM
rennocneb
p.1 #17 · Narrowed it down to One Einstein or 2 b800s ???
ordered the einstein, vagabond mini, and cyber synce triggers, also got the 32"x40" softbox. now wandering what other modifiers i should try to get.
Sep 28, 2012 at 02:58 PM
sic0048
p.1 #18 · Narrowed it down to One Einstein or 2 b800s ???
A Singh-Ray variable neutral density filter would be cheaper and a great alternative to trying to get a AB1600 to sync at higher shutter speeds.
Sep 29, 2012 at 08:47 AM
mshi
[X]
p.1 #19 · Narrowed it down to One Einstein or 2 b800s ???
http://www.bhphotovideo.com/c/product/374094-REG/Mola_MD220_Demi_22_Beauty_Dish.html
or
http://www.bhphotovideo.com/c/product/374097-REG/Mola_MS280_Setti_28_Beauty.html
Sep 29, 2012 at 08:58 PM
kenyee
p.1 #20 · Narrowed it down to One Einstein or 2 b800s ???
buy both, return one
Sep 30, 2012 at 09:01 PM
