Wedding Resource List
Archive 2012 · Randomly corrupted D700 Files
cbradio09
p.1 #1 · p.1 #1 · Randomly corrupted D700 Files
Getting a few files "damaged" per upload. Shows a ton of purple lines on the back of the camera. Doesn't seem to be camera specific but may be card specific.
Suggestions for diagnosing?
Sep 23, 2012 at 05:36 PM
hardlyboring
p.1 #2 · p.1 #2 · Randomly corrupted D700 Files
I would get new cards... If it is across the board I would think it is bad cards
Sep 23, 2012 at 06:03 PM
Scott Mosher
p.1 #3 · p.1 #3 · Randomly corrupted D700 Files
Maybe try the card in a different camera? If you can remember any specifics such as yiu shoot -> turn camera off quickly or anything else you did before it that may also narrow it down
Sep 23, 2012 at 06:04 PM
Nikon_14
p.1 #4 · p.1 #4 · Randomly corrupted D700 Files
I had the same problem. About once every ~60 frames, a file would be unreadable- sometimes 1 file by itself, sometimes 3 consecutive files, but usually 2 consecutive files.
So before using it at another event, I tested it out using my 2nd D700. When the same problem came up, Lexmark replaced it with no hassle.
Sep 23, 2012 at 08:23 PM
TimSid
p.1 #5 · p.1 #5 · Randomly corrupted D700 Files
Do you format your cards on your computer? If so, try formatting them in camera instead to eliminate any file-system induced errors.
Tim
Sep 23, 2012 at 08:51 PM
DavidCZ
p.1 #6 · p.1 #6 · Randomly corrupted D700 Files
Get a new card.
BTW, as Time said, format your card each time you use it for important events.
Sep 23, 2012 at 10:24 PM
awad
p.1 #7 · p.1 #7 · Randomly corrupted D700 Files
check the card reader as well. I had a FW800 reader that would start corrupting files as it transfered if I was dumping a lot of cards. Switching to my USB readers solves that problem.
Sep 24, 2012 at 04:51 AM
SloPhoto
p.1 #8 · p.1 #8 · Randomly corrupted D700 Files
Burn the card in a fire.....
Or you could just to a lowlevel format or chkdsk/fsck to see of there are bad sectors. Honestly though, you are in the wedding forum and shooting a camera with 1 card slot.... make that card go away.
(this is why I only use cameras with two card slots)
Sep 24, 2012 at 05:09 AM
