Archive 2012 · PROBLEM with Canon 1D Classic
Scott424
p.1 #1 · p.1 #1 · PROBLEM with Canon 1D Classic
Yesterday morning, I went to put a fully charged battery into the camera 1D Classic, and it instantly started flashing the dead battery symbol and 05 in the top LCD screen, even with the power turned off Tried my second battery fully charged but different brand with the same results. Any ideas out there? It did not flash "error" anything, just the 2 previously mentioned symbol and number. Thanks
Sep 23, 2012 at 12:09 PM
lexvo
p.1 #2 · p.1 #2 · PROBLEM with Canon 1D Classic
If I recall correctly, there is also a button cell battery in the 1D. Taking it out will kind of reset the camera. Maybe the button cell battery needs replacement? Of course this is just guessing on my part.
Sep 23, 2012 at 05:32 PM
Mickey
p.1 #3 · p.1 #3 · PROBLEM with Canon 1D Classic
At the age of that camera its probably the BIOS battery for the lack of a better term. It maintains the date, time, settings, etc when the main battery is removed. Crazy things start to happen when it begins to go dead. It's a small nickel size battery at the entrance of the main battery compartment. I'd try replacing it first.
Sep 23, 2012 at 06:30 PM
Scott424
p.1 #4 · p.1 #4 · PROBLEM with Canon 1D Classic
OK I changed that battery, #2505 for anyone else reading this, and it's still doing the same thing. I also plugged in the AC adapter, with the same results??
Sep 23, 2012 at 07:54 PM
gpop
p.1 #5 · p.1 #5 · PROBLEM with Canon 1D Classic
perhaps the battery is not the issue? try another lens or card?
(just guessing)
Sep 23, 2012 at 08:14 PM
Scott424
p.1 #6 · p.1 #6 · PROBLEM with Canon 1D Classic
(just guessing)
Yes I tried that first before anything. Must be time for an upgrade
Sep 24, 2012 at 12:29 AM
Mickey
p.1 #7 · p.1 #7 · PROBLEM with Canon 1D Classic
Check the battery contacts and make sure they are clean, camera and battery.
Sep 24, 2012 at 01:10 AM
Scott424
p.1 #8 · p.1 #8 · PROBLEM with Canon 1D Classic
I called CPS on fri and they were shocked that the code )% was flashing, because that is saying that the built in pop up flash is being obstructed! The only thing is.....there isn't one on a 1D body, and they also will not service that body anymore! Time for a new used one!!!!
Sep 30, 2012 at 08:38 PM
