5Dc ooc jpg - which setting?
Marcel VanEerd
p.1 #1 · 5Dc ooc jpg - which setting?
Hi there,
Experimenting with the JPG's from the 5D, I was a bit to see that a "Neutral" setting (all zeros) delivers dismal sharpness. Only at sharpness set at 3 or 4 do I feel sharpness is increased enough to call ooc shots to be acceptable.
Do you have similar experiences? I'd like to see what settings you prefer to use, realizing that this may change, depending on the subject.
FYI - I normally always shoot RAW (only, or RAW + JPG) and was trying to see how much "loss" there really is, using JPG.
Thanks!
Sep 19, 2012 at 04:01 PM
abqnmusa
p.1 #2 · 5Dc ooc jpg - which setting?
try "faithful" for accurate colors / set sharpness to 4 or 5
you just have to tune setting to your liking. more like what you would process RAW to l look like
I would just use RAW -- create the JPG or PNG file from the RAW
Edited on Sep 19, 2012 at 05:10 PM · View previous versions
Sep 19, 2012 at 04:05 PM
dgdg
p.1 #3 · 5Dc ooc jpg - which setting?
I needed that sharpness setting for my old rebel and 5Dc. I agree 'loss' is a loose word here.
I use raw now and haven't bothered with jpg in a while since quick delivery of pro photos is not an issue.
Agree with above post. You'll have to tweek the settings if you plan to use jpg in camera.
Sep 19, 2012 at 04:27 PM
Marcel VanEerd
p.1 #4 · 5Dc ooc jpg - which setting?
Thanks people. My main concern was that I forgot how to MF *... my RAW's proved differently, but still. Coming from a 1Dc, the jpg's from the 5Dc proved to be a bit of a surprise. At least I know now that the camera is ok, and not malfunctioning.
* Sooooo sad a split-focus or prism is so hard to find...
Sep 19, 2012 at 05:36 PM
parsons
p.1 #5 · 5Dc ooc jpg - which setting?
then you will also already know that the sensors are of different breeding, cmos being the latter and softer initially compared to a ccd chip.
Sep 19, 2012 at 07:45 PM
jay tieger
p.1 #6 · 5Dc ooc jpg - which setting?
Different bodies have anti-aliasing filters of different strengths, hence the different amount of sharpening required (either in-camera or in DPP or other software) to restore the image's original sharpness...
Sep 19, 2012 at 08:28 PM
Marcel VanEerd
p.1 #7 · 5Dc ooc jpg - which setting?
Knew both facts, but didn't apply that knowledge to the situation at hand. Thanks for pointing it out.
Sep 19, 2012 at 09:32 PM
jay tieger
p.1 #8 · 5Dc ooc jpg - which setting?
Another issue is file SIZE....with bigger files, more sharpening is needed.
Sep 20, 2012 at 02:23 AM
