Archive 2012 · File Size D800
Dan Heitman
p.1 #1 · p.1 #1 · File Size D800
I've recently purchased the D800 I moved up from the D300. Can I change the file size to 4500 x 4500 pixels after the shots have been taken. I use CS5. Thanks in advance. Dan
Sep 14, 2012 at 02:31 AM
James Burden
p.1 #2 · p.1 #2 · File Size D800
Yes
Sep 14, 2012 at 02:52 AM
Dan Heitman
p.1 #3 · p.1 #3 · File Size D800
Thanks James, would you care to elaborate on that : )
Sep 15, 2012 at 02:21 AM
James Burden
p.1 #4 · p.1 #4 · File Size D800
Sounds like you actually want to set up a 1:1 crop and you can do that with the crop tool. You won't be able to automate it though since the desired crop area would change from photo to photo.....
Sep 15, 2012 at 02:25 AM
JimFox
p.1 #5 · p.1 #5 · File Size D800
Hey Dan,
Under the "Image" menu, select "Image Size", you can change the size of the photo all you want. I use this in my downsizing my shots for the web. In your case, you just want to make them somewhat smaller.
I hope that helps,
Jim
Sep 15, 2012 at 06:32 AM
Rodolfo Paiz
p.1 #6 · p.1 #6 · File Size D800
The more interesting question is: what are you trying to achieve with this change, and is that the best way to do it? Unless you are specifically printing in a 15" x 15" square format, there's no particular reason I can think of for that specific conversion to be advantageous.
Sep 15, 2012 at 12:27 PM
Steve Perry
p.1 #7 · p.1 #7 · File Size D800
Also - keep in mind that if you want square, you need to be thinking about that when you're taking the photo. If your subject fills the entire frame and you "force" it to be square when you change the image size, you'll end up with a pretty distorted image.
Sep 15, 2012 at 01:05 PM
ckcarr
p.1 #8 · p.1 #8 · File Size D800
I posted these on August 13th.
As other's have said, you cannot program the camera to crop square. These are the available sizes, then crop from there.
FILE SIZES
14 bit:
FX 7360x4912 file size 38.8 mb
5:4 size 6144x4912 33 mb
1.2 size 6144x4080 27.8 mb
DX mode 4800x3200 17.2 mb
12 bit:
FX 7360x4912 file size 30.6 mb
5:4 size 6144x4912 25.9 mb
1.2 size 6144x4080 20.9 mb
DX mode 4800x3200 13.8 mb
I did not bother with the uncompressed. These were all lossless compressed.
Sep 15, 2012 at 01:36 PM
Bruce Sawle
p.1 #9 · p.1 #9 · File Size D800
For a square crop just use the crop tool and set it to 1:1. Then change the aspect ratio by going to image menue image size and putting the dimensions you want,
Sep 15, 2012 at 02:17 PM
pubtime
p.1 #10 · p.1 #10 · File Size D800
File size is the least of my concerns. The camera is a suckfest of softness once you add more than a few feet between you and the subject!
Sep 17, 2012 at 07:17 PM
workerdrone
p.1 #11 · p.1 #11 · File Size D800
Sep 17, 2012 at 07:20 PM
pubtime
p.1 #12 · p.1 #12 · File Size D800
Sorry, just venting all over the place. Nikon needs to recall this camera and get them fixed. I have all of my lenses finetuned at about -15 and that works until I add about 15', then nothing in the frame is in focus...nothing has any sharp detail...and the amount of grain at 250 makes me vomit!
Sep 17, 2012 at 07:28 PM
jlawrence
p.1 #13 · p.1 #13 · File Size D800
Return it if you have that many problems with it.
What's so hard about that?
Sep 17, 2012 at 08:34 PM
workerdrone
p.1 #14 · p.1 #14 · File Size D800
The camera is a suckfest of softness once you add more than a few feet between you and the subject ??
I added a few feet between me and my subject this weekend - hot air ballooning. I'm a post processing dunce but I'm still stunned by the clarity and detail this camera provides. See this handheld takeoff shot and approximately 200% crop. Sounds like you got a dud. Have you sent it in to have them make it right?
So, to the OP, it's a cropper's dream
24-70 @ 70mm
Sep 17, 2012 at 10:02 PM
