Archive 2012 · New 1 system lens....
lxdesign
p.1 #1 · p.1 #1 · New 1 system lens....
Long overdue! Another addition to the lineup of 1 system lenses... 18.5mm f/1.8 which is effectively a 50mm 1.8 lens.
http://en.nikon.ca/Nikon-Products/Product/Nikon1-Lenses/3324/1-NIKKOR-18.5mm-f%252F1.8.html
Sep 13, 2012 at 04:44 PM
DTOB
p.1 #2 · p.1 #2 · New 1 system lens....
Finally, an interesting lens.
Sep 13, 2012 at 04:46 PM
gugs
p.1 #3 · p.1 #3 · New 1 system lens....
+1
Sep 13, 2012 at 09:30 PM
Kittyk
p.1 #4 · p.1 #4 · New 1 system lens....
i will not comment about it being equivalent to 50mm f1.8 and on the price and on the system as a whole
Sep 13, 2012 at 10:15 PM
lou f
p.1 #5 · p.1 #5 · New 1 system lens....
shots look good, a 35mm would have been nicer.
Sep 13, 2012 at 11:26 PM
gfiksel
p.1 #6 · p.1 #6 · New 1 system lens....
But of course... Make the sensor 2 mm in size and the lens, all of a sudden, becomes 200mm/1.8
Sep 14, 2012 at 01:12 AM
gman1339
p.1 #7 · p.1 #7 · New 1 system lens....
Not a bad price if it can focus fast. My $105 nifty 50 is a 135mm f/1.8 on my V1.
Sep 14, 2012 at 01:25 AM
lxdesign
p.1 #8 · p.1 #8 · New 1 system lens....
You mean a $255 nifty fifty ..after adding the FT1 cost...
Sep 14, 2012 at 02:26 AM
gman1339
p.1 #9 · p.1 #9 · New 1 system lens....
Can I divide the price of the FT1 by 7 since I use it with 7 f-mount lenses? :-)
Sep 14, 2012 at 02:38 AM
ytwong
p.1 #10 · p.1 #10 · New 1 system lens....
$255 50 1.8 equivalent lens without stabilization.. a bit much.
another new lens without optical stabilization, I wounder if they are going to release a body with built-in stabilization (to reduce overall system size?).
Sep 14, 2012 at 02:46 AM
Kittyk
p.1 #11 · p.1 #11 · New 1 system lens....
it is actually more like 135 f4 with not really that sharp f4
Sep 14, 2012 at 01:50 PM
DTOB
p.1 #12 · p.1 #12 · New 1 system lens....
I've never found a need for stabilization in my own shooting. None of my lenses have VR, not something really on my radar. None of my film cameras had built in VR...I guess ignorance is bliss eh?
Sep 14, 2012 at 02:20 PM
lxdesign
p.1 #13 · p.1 #13 · New 1 system lens....
Ya.....that works
Sep 14, 2012 at 03:17 PM
lxdesign
p.1 #14 · p.1 #14 · New 1 system lens....
For the 10mm lack of stabalization is not an issue. And I suspect that it will be similar for the 18.5mm
Once you get into the 35mm and beyond range its nice to have.
Sep 14, 2012 at 03:18 PM
gman1339
p.1 #15 · p.1 #15 · New 1 system lens....
It's only an f/4 (actually closer to f/4.8) as far as depth of field, not light capturing abilities.
Sep 14, 2012 at 03:23 PM
Rags Hef
p.1 #16 · p.1 #16 · New 1 system lens....
It's good to see Nik is not giving up on the N1 line. Just sold my V1 at a relatively large loss.
I kept my FT1 & 10mm, for a V2. A V2 I will inspect a lot more closely if I buy
The VR is less necessary after SS500 and can be an obstruction shooting bursts; altho' not as bad as picture review can be in the V1
Sep 14, 2012 at 04:09 PM
Kittyk
p.1 #17 · p.1 #17 · New 1 system lens....
that is also relative. I was not really that excited to see low light performance from that chip. would definitely rate it two or more stops under D700, let alone D3s or D800
Sep 14, 2012 at 04:52 PM
gman1339
p.1 #18 · p.1 #18 · New 1 system lens....
Too many people are worried about the wide end. The 1" chip gives you a 2.7 crop factor. I put my V1 on the back of my 300 2.8 VR with the 1.7 TC and I'm at a 1377mm FOV.
The Del Monte Center is 1.15 miles from my shooting location.
http://www.sprowlsstudios.com/web/_DSC0239.jpg
Sep 14, 2012 at 06:40 PM
Kittyk
p.1 #19 · p.1 #19 · New 1 system lens....
Too many people care about long end imo.
sure it does have some benefits, but no doubt nikon failed in that one. They could create such specialty camera first when we have full frame rangefinder in our hands.
personally i cannot find any use for anything beyond 105mm except peeking in other's windows
Sep 14, 2012 at 06:51 PM
workerdrone
p.1 #20 · p.1 #20 · New 1 system lens....
^color me wowed, gman
I could see removing the D4/D800 off of the exotic tele just to grab some extra shots with ridiculous reach on the V1- that's some impressive quality, and it's not like it adds any weight or size to the kit now does it?
Does something like this require perfect long lens technique and a rock of gibraltar tripod?
Sep 14, 2012 at 06:57 PM
