FM Actions & Plugins support
Workflow Guidelines
PC to imac possible switch
kentvinyard
p.1 #1 · PC to imac possible switch
I am using a PC right now and thinking about switching to an imac 21.5" or a 27 " if I can swing it. Will I be able to license the Nikon NX2 over to the imac or do they make you purchase new software? I am also using photoshop CS5 and would like to switch it over to the mac without having to buy new software. Can this also be done. Thanks in advance for the info.
Kent
Sep 01, 2012 at 07:26 PM
EGrav
p.1 #2 · PC to imac possible switch
I don't know about Nikon, but Adobe let's you switch. No problem.
Sep 01, 2012 at 10:55 PM
Paul_K
p.1 #3 · PC to imac possible switch
If you have an original CD for Capture NX2, I think you will have a product key code that you can use for both the Mac and PC version
I believe the same applies for the downloadable version
Sep 01, 2012 at 11:05 PM
kentvinyard
p.1 #4 · PC to imac possible switch
Thanks for the info guys.
I have the origional cd for all of those program so I guess I should be Ok.
Sep 02, 2012 at 12:06 AM
lou f
p.1 #5 · PC to imac possible switch
i have cnx2 running on my mac and pcs, same code.
Sep 02, 2012 at 11:00 AM
rodmcwha
p.1 #6 · PC to imac possible switch
I downloaded NX2 and used my original code-no problem.
I went with the 27" and couldn't be happier!
Sep 03, 2012 at 03:34 PM
kentvinyard
p.1 #7 · PC to imac possible switch
EDIT*
I just downloaded CNX2 from Nikon and was able to install it on Lion. Thanks for all the info.
Sep 22, 2012 at 12:53 AM
sic0048
p.1 #8 · PC to imac possible switch
Adobe will generally allow you to switch platforms (Windows to OSX) for a nominal fee (like $30), BUT you must be on the current version. Since you have CS5, they will not change that license for you. You will have to at least upgrade it to the latest version (CS6) before they will let you change.
Sep 22, 2012 at 03:44 PM
k7xd
p.1 #9 · PC to imac possible switch
You might want to wait until the new iMacs come out.
Rumors they are finally ditching the horrible glossy display.
Sep 22, 2012 at 11:56 PM
