What are the criteria?
Is this Creepy ???
oldrattler
p.1 #1 · Is this Creepy ???
The weekly assignment is "Creepy"... I couldn't sleep last night so I started shooting... This is a 4 image blend... (1) Hall in full light... (2) Hall with light from room only (open door)... (3) Hall with no light (30 second bulb exposure)... (4) 580 flash set to full power, positioned in room and triggered with the ST-e2 (me in doorway)... When I blended in CS5 this is what I got... Your opinion is requested... Creepy... Not creepy /Just weird... Are you a moron Thanks for looking, Jim
Added a second image with a hand blend of the layers... Is this Better or worse... Remember::: we want it creepy... Thanks
  Canon EOS-1Ds Mark II    40 mm    f/8.0    100 ISO    0.0 EV
Hand blended
Edited on Aug 30, 2012 at 11:47 PM · View previous versions
Aug 30, 2012 at 02:22 PM
ben egbert
p.1 #2 · Is this Creepy ???
Creepy it is.
Aug 30, 2012 at 02:34 PM
Travis Rhoads
p.1 #3 · Is this Creepy ???
I think it would be a lot creepier without the weird halos that are happening, the gray toned areas. I can see it looking very ghostly, and ghosts are creepy. Could you take one that is the hall without you in it...then one with you, and put just you on an opacity layer to give the ghost effect?
Aug 30, 2012 at 04:32 PM
oldrattler
p.1 #4 · Is this Creepy ???
ben egbert wrote:
Creepy it is.
Thanks Ben...
Aug 30, 2012 at 04:35 PM
oldrattler
p.1 #5 · Is this Creepy ???
Thanks Travis... I really do not know where the grey came from... At 4 AM things get pretty weird.. I'll try just blending two as you suggest...
Aug 30, 2012 at 04:37 PM
Travis Rhoads
p.1 #6 · Is this Creepy ???
are the images manually blended, or software blended?
Aug 30, 2012 at 04:39 PM
oldrattler
p.1 #7 · Is this Creepy ???
Software... I used CS5 photomerge...
Aug 30, 2012 at 05:34 PM
AuntiPode
p.1 #8 · Is this Creepy ???
Second, creepy. Needs to be much darker to be really creepy.
Aug 31, 2012 at 02:29 AM
Travis Rhoads
p.1 #9 · Is this Creepy ???
yeah, the second hand blended one is much creepier, I didn't even spot the knife in the first one. I agree, needs to be a bit darker, the light coming from the room is too bright too IMO.
Aug 31, 2012 at 10:42 AM
Camperjim
p.1 #10 · Is this Creepy ???
I doubt this image is worth the effort, but here is a quick revision. Lots more could be done but you really need to work on the original instead of the downsized image.
Aug 31, 2012 at 04:46 PM
oldrattler
p.1 #11 · Is this Creepy ???
Thank you Karen
Aug 31, 2012 at 04:52 PM
oldrattler
p.1 #12 · Is this Creepy ???
Thanks Travis... I will darken slightly before posting in WA... Jim
Aug 31, 2012 at 04:53 PM
oldrattler
p.1 #13 · Is this Creepy ???
Thank you Jim... There actually was not original as I shot over 50 images with the intent on blending... I was after a curtain look, visualized in my minds eye... I haven't got it yet but I will keep trying... Again, Thank you, Jim
Aug 31, 2012 at 04:57 PM
