What are the criteria?
Is it flat ?
Bsmooth
p.1 #1 · Is it flat ?
Bit of a misalignment in the background, but let me know how it looks please.
Aug 28, 2012 at 01:09 AM
sbeme
p.1 #2 · Is it flat ?
The textures seem to flow almost uninterrupted from ground to cairn, losing some definition in the process. I would do some selective burning to create a bit more depth and contrast.
Horizon could be leveled. A bit of distortion most noted in the curvature of the horizon.
Since this is nearly monochromatic, you might consider a BW interpretation.
OK if I post one?
Scott
Aug 28, 2012 at 01:12 AM
Bsmooth
p.1 #3 · Is it flat ?
Sure go ahead and post a B/W. I actually changed the contrast quite a bit already, but what would you do to create more depth and contrast ?
This seems to be a continuing theme in most of my posted images, so I would like to know how to fix it.
I could have changed it by taking it at a different time of day, but this was the best I could do at the time.
Aug 28, 2012 at 01:35 PM
sbeme
p.1 #4 · Is it flat ?
I'll post a BW variation when I get home tonight.
Aug 28, 2012 at 02:25 PM
ben egbert
p.1 #5 · Is it flat ?
Everything looks gritty to me. I used to get this when I applied too much Topaz sharpening. Topaz never warned of oversharpening with halos.
Aug 28, 2012 at 02:39 PM
RustyBug
p.1 #6 · Is it flat ?
Took a stab at it to try and add some definition / separation.
Kind of a tough composition, with the BG lines cutting across it as much as it does.
Aug 28, 2012 at 03:46 PM
Bsmooth
p.1 #7 · Is it flat ?
So what did you do to try add seperation and definition? Darken the bottom rock to try and seperate it from the ground rocks?
I didn't see any haloes, are there any? The only sharpening I did was to the rocks after I added a layer mask to seperate the sky and ocean from the rocks and shoreline.
I actually added a bit of blur to the background , just not a lot.
Maybe what I should have done initially was to get down lower and shoot the rocks with more of the sky in the background.
Aug 28, 2012 at 04:19 PM
RustyBug
p.1 #8 · Is it flat ?
A little selective gamma variation push/pull, as well as some selective blur/sharp push/pull.
+1 @ Ben's comment @ gritty. I tried to pull that back also.
Aug 28, 2012 at 04:37 PM
sbeme
p.1 #9 · Is it flat ?
Did some local burning to darken shadows, add contrast between lighter and darker rocks. BW conversion in Silver Efex. A bit of selective clarity reduction over the foreground with a bit of vignette.
Corrected horizon, distortion.
A bit of burning in the sky.Tried to get a bit more alternating lighter/darker elements including chosing the sky luminosity via color sliders during the BW conversion. Selective brightness decrease over the cairn in SEP.
Scott
Aug 29, 2012 at 12:24 AM
sbeme
p.1 #10 · Is it flat ?
btw, did you use some local contrast enhancement/detail extraction? Wondering about the grainy texture throughout the foreground sand/rock/stone.
Aug 29, 2012 at 12:27 AM
Bsmooth
p.1 #11 · Is it flat ?
I did try a little sharpness enhancement. But tonight I went back in and tried again from scratch, hopefully its better. It is a different set of images too, hence the waves and boat.
Aug 29, 2012 at 12:38 AM
Bsmooth
p.1 #12 · Is it flat ?
Thats a great B/W conversion, but how did you straighten that horizon?
I plain don't understand this new Crop tool, it just doesn't seem to work right.
Aug 29, 2012 at 01:56 PM
sbeme
p.1 #13 · Is it flat ?
Thanks.
Correction in LR3.
Went to Lens Correction, Manual and played with the distortion slider to get a straight horizon. Then used the ruler tool in Crop to stretch a line horizontally across, hit enter and the rotation is made.
Scott
Aug 29, 2012 at 06:35 PM
