Serial Numbers...or lack of
waynemac
p.1 #1 · Serial Numbers...or lack of
I'm taking my first foray into L glass and have been looking for a 70-200mm L 2.8 II. I have seen some advertised as not having a serial number. What does this mean? Some kind of gray market or fake? A little confused....Thanks in advance.
Aug 25, 2012 at 03:14 PM
EB-1
p.1 #2 · Serial Numbers...or lack of
Maybe no date code? The lens should have a serial number somewhere. Mine is on the barrel.
Aug 25, 2012 at 03:19 PM
gvg45
p.1 #3 · Serial Numbers...or lack of
Must be a misunderstanding. The newer 70-200mm f/2.8 II do not have date codes, but they should all have a serial number.
Aug 25, 2012 at 03:42 PM
burningheart
p.1 #4 · Serial Numbers...or lack of
Unless the it was stamped on the mount and the mount was replaced or stamped on a part that was replaced. My 24 L MKII the serial number is stamped on the mount.
That said if it is a new lens the serial number should appear somewhere
Aug 25, 2012 at 04:15 PM
Monito
p.1 #5 · Serial Numbers...or lack of
waynemac wrote: I'm taking my first foray into L glass and have been looking for a 70-200mm L 2.8 II. I have seen some advertised as not having a serial number. What does this mean? Some kind of gray market or fake? A little confused....
It means don't believe everything you read.
All Canon lenses have serial numbers.
Aug 25, 2012 at 05:20 PM
Gochugogi
p.1 #6 · Serial Numbers...or lack of
Sounds like an illegal firearm.
Aug 25, 2012 at 05:48 PM
sirimiri
p.1 #7 · Serial Numbers...or lack of
All Canon EF bodies and lenses are serialized. So, it should not be absent.
Aug 25, 2012 at 05:54 PM
Gochugogi
p.1 #8 · Serial Numbers...or lack of
True, but several of my EOS the SN on the bottom wore off from contact with my hand (no scratches or rubs). It's merely printed on a plastic label not very durable. Also, when the rear mount of a lens is repaired the new part lacks whatever date code was originally imprinted. However, it is burned into the ROM so no biggie if must know what it is.
Aug 25, 2012 at 06:50 PM
