File Naming Curious Behavior in 5D3
Doctorbird
p.1 #1 · File Naming Curious Behavior in 5D3
To be precise, here's my problem.
In the filenaming menu: I set the first 3 characters to 5D3 in User Setting 2. I registered User Setting 2. On upload to Lightroom these characters became _D3 in the filename. What am I doing wrong? No satisfactory answer here means a trip to Canon Service.
Thanks in advance.
Db.
Aug 20, 2012 at 04:50 AM
kdlanejr
p.1 #2 · File Naming Curious Behavior in 5D3
You're not doing anything wrong. You have your colorspace set to AdobeRGB. The leading underscore in the filename indicates this. If you're shooting in raw, change your colorspace back to sRGB to get your first character back. Raw processing doesn't care about the color space setting in the camera, and if you're shooting jpegs, you're better off shooting sRGB so your jpeg colorspace doesn't have to be changed later.
Aug 20, 2012 at 05:13 AM
Doctorbird
p.1 #3 · File Naming Curious Behavior in 5D3
Wow, many thanks. I didn't notice this in the manual, or skipped over it in the color space section.
Db.
Aug 20, 2012 at 05:25 AM
caisheng
p.1 #4 · File Naming Curious Behavior in 5D3
Lesson learned, thanks.
Aug 20, 2012 at 06:50 AM
Monito
p.1 #5 · File Naming Curious Behavior in 5D3
Use auto-renaming software to assign more meaningful names and to avoid clashes at the 10000 image rollover.
I use DIM 4 to download images from the card reader and automagically rename them to YYYYMMDD-hhmmss.CR2 and automatically make a copy on the backup drive simultaneously. Then I can go from any finished image or any image file in any stage of workflow to the Raw image file or to other stages.
Aug 20, 2012 at 07:06 AM
