James_N Offline Upload & Sell: Off
p.1 #6 · Photoshop CS6 Set-up Help | |
JimmyStephans wrote:
Thanks - that helps...
It also confuses me. I was under the impression that most web browsers don't handle Adobe RGB very well and that regular RGB was best.
I'm going to try this.
All that means is that if you intend to publish to the Web, or print with a printer that only accepts sRGB, then you'll need to use the Edit > Convert to Profile > sRGB option in Photoshop. You can even write an action that does this automatically for you.
And because the Profile Mismatches options are not activated, you can still use ProPhoto RGB when transferring in images from Lightroom or Adobe Camera Raw and Photoshop will honor that color space.
