dsjtecserv Online Upload & Sell: Off
p.1 #5 · Cokin P system and wide angles? | |
The Cokin Z-Pro system is the next-largest size, and uses 100 mm filters. Note that the risk of vignetting is different for different lenses, independent of the focal length, so it is difficult to make generalizations based on focal length alone. The holder itself does not vignette, but the stacked slot holders on the side can catch the corners. I found that on APS-C the Canon 10-22 was good down to 11 mm, and the soft vignetting wasn't necessarily objectionable at 10 mm. On full frame, I've found that the 17-40 vignettes at about 17-18. On the Z-Pro the filter slots are removable, so if you take off one or two of them, vignetting can be avoided for most lenses.
Dave
