Variable ND filters
fastw
p.1 #1 · Variable ND filters
Are they any good, or should I just get a fixed one(s)?
Cheers.
Aug 17, 2012 at 09:20 AM
Monito
p.1 #2 · Variable ND filters
I recommend fixed ones.
What concerns do you have about them after doing your internet searches? There are lots of opinions about them you can find.
Aug 17, 2012 at 10:55 AM
mMontag
p.1 #3 · Variable ND filters
Do a search on the Gear Forum (and Canon) - many ND threads to be found.
If you're needing wide to ultra-wide and already using an ND / GND holder - used fixed. If not the variable ND's should work.
Aug 17, 2012 at 11:55 AM
Tenn.Jer
p.1 #4 · Variable ND filters
I've used a Singh-Ray Vari-ND for a few years, and I like the convenience; indispensable for bright light waterfalls/waves...still, a 77mm was expensive, 16-35 & 24 TS-E lenses are 82mm, and ultra-wides often (usually?) require a filter holder because of bulging elements...so, simplicity can be limiting. I don't shoot much really wide, so I haven't re-invested in holders since I switched from film, and only occasionally miss the ol' bag-o-filters...
Jerry
Aug 17, 2012 at 01:05 PM
thedruid
p.1 #5 · Variable ND filters
I have both but find the fixed one is what I carry, the Sing Ray does not go wide enough for my taste. You also have to deal with this cross polarization look on blue skies, totally unusable, so I mostly pack the B+W 10 stop ND.
Aug 17, 2012 at 01:11 PM
