D7000 Top LCD issue.... ?
mlife
p.1 #1 · D7000 Top LCD issue.... ?
I bought a D7000 as my travel/vacation body and over the last few weeks have noticed something odd. On occasion (no pattern) I will turn the camera off and the top LCD will stay on for like 10min after the camera is shut off. When I turn the camera back on the SD slot 1 icon is flashing and it dispays slot 2 as the default memory. It wont write to the card in slot 1. I have removed the card, replaced the card, formated the card and even switched the cards from slot one and two around. It may be worth mentioning that Im using a PNY Pro-Elite 16GB class 10 (35MB/s) card so I don't think thats an issue. Again it doesn't happen all the time but has happened about 3 times in the last month or so....
Any ideas?
Aug 15, 2012 at 03:28 PM
trenchmonkey
p.1 #2 · D7000 Top LCD issue.... ?
3rd party grip I've heard of that before. I'm on my 7th...never had that happen
so I'd be guessin' here. GL
Aug 15, 2012 at 03:31 PM
mlife
p.1 #3 · D7000 Top LCD issue.... ?
I do have a 3rd party grip but its only been used a few times and issue has occurred without grip attached, like this morning.
Aug 15, 2012 at 03:36 PM
davidnholtjr
p.1 #4 · D7000 Top LCD issue.... ?
Could be the card.
When I bought my D3200 I picked up a PNY Pro-Elite 16GB class 10 card and at first everything was good, then the camera was having problems recording video and then still pics. Got home and tried a couple other brand cards (sandisk and Panasonic) and all worked fine, The card was bad. took it back and then the something happened twice with replacement cards.
So I say away from PNY now. Replaced it with a SanDisk 16GB Extreme Class 10 UHS-I and it works great.
Aug 17, 2012 at 02:48 PM
mlife
p.1 #5 · D7000 Top LCD issue.... ?
Actually that thought crossed my mind, so I just ordered a new sandisk.. should be here tomorrow... Ill let you know.
thanks for the input.
Aug 17, 2012 at 03:43 PM
