Archive 2012 · Is it 1120 or 1456?
rprouty
p.1 #1 · p.1 #1 · Is it 1120 or 1456?
Using an 800 on a 1DIV with a 1.4X Extender the EXIF reports Focal Length as 1120mm.
Is that correct?
If you figure the 800 and the 1.3 Crop of the body and the 1.4X extender it's 1456mm.
Is this correct?
Thanks
Rod
http://www.pbase.com/rprouty/image/134288026/original.jpg
Aug 10, 2012 at 09:20 AM
gowhow
p.1 #2 · p.1 #2 · Is it 1120 or 1456?
the focal length doesn't change just because it is on the crop body. So the answer is 1120
Aug 10, 2012 at 09:25 AM
15Bit
p.1 #3 · p.1 #3 · Is it 1120 or 1456?
I would say that the focal length is 1120mm (1.4X800mm), but the field of view is equivalent to 1456mm (1.3X1120) due to your cropping out a section of the image.
An alternative way to think about it - if you take a photo with a 50mm lens and then crop it in photoshop, you still used a 50mm lens, even if the final image has an equivalent field of view to a 100mm lens.
Aug 10, 2012 at 09:39 AM
Ian.Dobinson
p.1 #4 · p.1 #4 · Is it 1120 or 1456?
As far as I've ever seen the exif always reports the TRUE focal length rather than the 35mm equivalent.
In the same way my 7D reports the long end of my 100-400 as 400 rather than 640 (it's not a 640mm lens)
Aug 10, 2012 at 11:01 AM
Lars Johnsson
p.1 #5 · p.1 #5 · Is it 1120 or 1456?
It's the exif data from the lens. Focal length is not a combination of exif data from lens and body together. Lens is this case is of course lens and tc together
Aug 10, 2012 at 12:20 PM
Yakim Peled
p.1 #6 · p.1 #6 · Is it 1120 or 1456?
1120 with AoV of 1456.
Happy shooting,
Yakim.
Aug 10, 2012 at 02:46 PM
Jim Victory
p.1 #7 · p.1 #7 · Is it 1120 or 1456?
What they said!
Nice detail wide open Rod.
Jim
Aug 10, 2012 at 05:25 PM
rprouty
p.1 #8 · p.1 #8 · Is it 1120 or 1456?
Thanks Jim
Aug 10, 2012 at 05:26 PM
Gib Robinson
p.1 #9 · p.1 #9 · Is it 1120 or 1456?
And nice exposure. Did you need any compensation?
--Gib
Aug 10, 2012 at 05:31 PM
rprouty
p.1 #10 · p.1 #10 · Is it 1120 or 1456?
Here's the info:
Full EXIF Info
Date/Time 28-Apr-2011 16:33:24
Make Canon
Model Canon EOS-1D Mark IV
Flash Used No
Focal Length 1120 mm
Exposure Time 1/320 sec
Aperture f/8
ISO Equivalent 400
Exposure Bias +1
White Balance
Metering Mode matrix (5)
JPEG Quality
Exposure Program aperture priority (3)
Focus Distance 58.5
Aug 10, 2012 at 06:01 PM
Eric Gottesman
p.1 #11 · p.1 #11 · Is it 1120 or 1456?
You just needed an excuse to post a fabulous picture. Great capture!
Aug 10, 2012 at 06:06 PM
Dragonfire
p.1 #12 · p.1 #12 · Is it 1120 or 1456?
Long enough to get the shot
Aug 10, 2012 at 10:21 PM
EB-1
p.1 #13 · p.1 #13 · Is it 1120 or 1456?
Seriously? You know what it is.
Aug 10, 2012 at 11:40 PM
rprouty
p.1 #14 · p.1 #14 · Is it 1120 or 1456?
I guess you're the expert on everything, I'm not that's why I asked the question.
Aug 10, 2012 at 11:45 PM
