pbraymond Offline Upload & Sell: On
p.1 #13 · D800 users: Are 36 MP an anchor for your computer | |
taob wrote:
Michaelparris wrote:
I have a Mac with 2.66 Ghz core 2 Duo and 8 Gb of Ram. How much difference will I see compared to my 5D MKII files
It depends on how much of your system's resources are used right now processing 5D2 files. A lot of people here are saying "just upgrade RAM". That only makes sense if RAM is a bottleneck. In many cases, it is not. For instance, I am processing thousands of D800 files in Bridge (same applies to Lightroom). If you already have 8 GB of RAM, adding more of it won't really help you much. Bridge and LR effectively only load up one image at a time, so their RAM requirements are much lighter than, say, Photoshop. I have 16GB installed on my system, and while I'm powering my way through the raw processing step, the system never goes much beyond 6 GB of RAM. That's with Chrome, OpenOffice, etc. running along with whatever background processes are there (Google Drive, Explorer, KeePass, etc.)
On the other hand, if you do a lot of work in Photoshop, open up several images at once, use a lot of layers, etc. then adding more RAM could be a benefit to you. Basically, figure out where the bottlenecks are (or will be) in your system, and address those in priority order. If you're using Adobe products, bumping up your GPU won't do anything. You might need more disk space before anything else. Or perhaps just faster disk (e.g., I upgraded to SSDs for my working files). Perhaps your CPU is maxed out because that shiny new SSD is able to shovel file data at it faster than the CPU can process it. There is no one universal answer to your question.
Agree with the comment on LR and RAM. I'm running an overclocked i5 and LR never uses much beyond 4 GB of RAM with D800 RAW (and I have 24GB) but the CPU is maxed out at 100% during previews and adjustments in LR develop module. I know an overclocked i7 would help; if the CPU is at 100% I doubt even SSD would speed things up significantly.
And yes, the D800 files do take a lot longer than D700 files (have not measured), but it's very noticeable. I see 3 -5 second processing after adjustments in the develop module, compared almost instantaneous (amybe 1s) with D700 files in LR4.x. To be fair, LR3.x did not support D800 files, so I may be a little spoiled by the speed of LR3.x on D700 files and it's now clouding my judgement.
