FM Actions & Plugins support
Workflow Guidelines
Color Efex Pro 3.0 and CS6 64bit
markymarc
p.1 #1 · Color Efex Pro 3.0 and CS6 64bit
Has anybody gotten their Color Efex Pro 3.0 version to work with CS6 64bit? The latest version 3.110 works well with Photoshop CS5.1 64bit. I also can move the Color Efex folder to CS6 32bit version and it works well there. But it will not work with the 64bit CS6 version.
I realize Color Efex 4.0 is out there and officially supports CS6 64bit. But I do not see the need to upgrade and it seems that I am close to making it work with CS6 64bit. If it works with CS5.1 64bit and it works with CS6 32 bit, gosh, it should work with CS6 64bit. I am guessing there is some plugin registration that is going on with respect to CS6.
Any ideas.
Thanks!
Aug 06, 2012 at 03:25 PM
gabimaster
p.1 #2 · Color Efex Pro 3.0 and CS6 64bit
I'm afraid you will have to update to Color Efex 4.
Aug 06, 2012 at 05:45 PM
Lovesong
p.1 #3 · Color Efex Pro 3.0 and CS6 64bit
Mine works fine. Running CS6 Extended on OSX 10.8, v. 3.110 Efex Pro. FYI, Sharpener Pro and SilverEffex 1.x work fine as well
Aug 07, 2012 at 04:15 AM
markymarc
p.1 #4 · Color Efex Pro 3.0 and CS6 64bit
Update: I got Color Efex Pro 3.0 v3.110 to work with CS6 64bit on Windows 7.
My problem was that my test bed was 32bit so the 64bit Photoshop never got installed.
So i reinstalled CS5 64bit on a different machine and if you move the Nik Color Efex Pro Complete folder over, it will work with CS6. Phew.
Aug 08, 2012 at 12:38 PM
gabimaster
p.1 #5 · Color Efex Pro 3.0 and CS6 64bit
Really ?Color Efex Pro 3 works with CS5 64 bit ? That's good ! I'll try to update.
Aug 08, 2012 at 01:41 PM
markymarc
p.1 #6 · Color Efex Pro 3.0 and CS6 64bit
It sure does! Keep in mind that with just CS6 64bit installed, Color Efex Pro 3.0 v3.110 Complete will not extract the 64bit files and definitely will not identify the CS6 64bit Photoshop folder. I tried to to trick it by creating a dummy folder but either was unsuccessful with the naming convention or it really needed the full install of Adobe CS5.
So I ended up installing CS5 (five) 64bit. Then you install v3.110 and then move the Color Efex Pro folder over to the CS6 64bit Plugin folder. It will see it then. You might need to move the Selective Tools folder over as well. Try it first without it.
Note: v3.110 is the version that works with 64bit Photoshop. So if you have a earlier version, call Nik up and get the latest v3.110. They owe you that!
Aug 08, 2012 at 01:47 PM
