jzucker Offline Upload & Sell: On
p.1 #4 · Imag Portraiture VS Portrait Proffesional ? | |
I use both. They are totally different packages with completely different approaches. Portraiture 2 is simply a skin softening program. Seems to me it uses an algorithm which essentially does the equivalent of this:
1) Create skin mask
2) Create a surface blur of the unmasked areas (skin)
3) Add a texure overlay to recover some skin texture
Whereas PP does something like this
1) Create skin mask
4) Performs eye whitening
5) Bumps iris contrast and lightens
6) Creates dodge/burn layer and adds contouring
7) Performs teeth whitening
8) Performs lip darkening
9) Performs spot removal
10) Performs feature enhancement
- Includes lip enhancement
- Includes liquifying eyes, cheeks, nose, chin
- Changes highlighting and color of hair
- etc.
Item #10 is one of the controversial ones. Fortunately, it can be disabled either globally or individually
Item 9 is the subject of the thread that was alluded to in the previous posting. It is extremely buggy and I always turn it off because it creates jpg-compression-like artifacts about 50% of the time. Very bad. Also, it doesn't do a good enough job to avoid having to do blemish retouching manually. You still will need to use the healing brush.
My take is that PP is a very good product with some bugs. In addition to the blotchy skin, it's very poor at non standard face angles including profiles.
However, if I manually perform the edits that PP does, it may take me hours whereas I can perform them in PP in minutes. I can probably do a better job manually but most of the time, PP does a perfectly acceptable job.
