Focus with EVF on NEX 5N
esanchez
p.1 #1 · Focus with EVF on NEX 5N
Is it easier to focus manual lenses on the NEX 5N with the EVF? I have been thinking about buying the EVF or buying a NEX 7 for the EVF. I want to buy some manual lenses but I'm not sure if it's easy to focus the manual lenses with the EVF.
Jul 30, 2012 at 02:03 AM
mawz
p.1 #2 · Focus with EVF on NEX 5N
It's extremely easy to focus manual lenses with the EVF, definitely easier than with the rear LCD as you have a higher-resolution display (0.8MP vs 0.3MP actual resolution, the dot resolution counts all three sub-pixels to give more impressive numbers) and a clearer view of it. You have two different types of focus assist: peaking, which takes practice to judge and can be inaccurate with low-contrast scenes or very shallow DoF, and magnification, which is 100% accurate but can be a pain with longer lenses hand-held.I use a mix of both with the NEX-7, as I did with the 5N before I upgraded. Frankly, I find the Sony EVF to be superior to any OVF (TTL or RF) for accurate focusing.
There are other issues with EVF's though, most notably lag in tracking fast-moving objects, a greater susceptibility to problems from light leakage (amplified by the lousy Eyecup on the NEX EVF's) and the fact you need to pick between a high-contrast display with blocked shadows for good peaking performance or a lower contrast display without blocked shadows. Note these settings are achieved by using different JPEG settings, for many reasons I don't really recommend shooting JPEG on Sony cameras for serious shooters, RAW is required to get anywhere near the maximum IQ the camera is capable of, JPEG settings should be used to control the EVF/LCD display. Some users also find the low frame rate of the LV feed in really low light to be disconcerting or problematical.
Jul 30, 2012 at 02:17 AM
snapsy
p.1 #3 · Focus with EVF on NEX 5N
Easier to focus and definitely easier to stabilize the camera.
Jul 30, 2012 at 03:53 AM
slungu
p.1 #4 · Focus with EVF on NEX 5N
That is something that I am also interested in, since my M-mount lenses with adapter all focus past infinity so using the mechanical infinity focus is not an option and with the LCD it is still a hard thing to do even with a 35mm lens.
Regards, Stefan
Jul 30, 2012 at 09:46 AM
TSY87
p.1 #5 · Focus with EVF on NEX 5N
I actually prefer the flexible EVF option on the nex5n over the rigid nex7. Problem is, I much prefer the nex-7 overall over the 5n.
I strictly use MF lenses on my nex-7.
Jul 30, 2012 at 08:07 PM
JimBuchanan
p.1 #6 · Focus with EVF on NEX 5N
Regards, Stefan
You may want to try shimming the adapter. Use brass shim material and start with maybe .002" thick. I think my adapter needed about .004".
Jul 30, 2012 at 08:27 PM
slungu
p.1 #7 · Focus with EVF on NEX 5N
I had an attempt with aluminium but I was somehow worry that I might introduce other problems if the shiming is not exactly the same thickness around the mount, so dicarded that possibility in the end. Maybe I should try it again.
Regards, Stefan
Jul 31, 2012 at 10:02 AM
mMontag
p.1 #8 · Focus with EVF on NEX 5N
Stefan,
Try aluminum tape - very easy to work with - press it on oversized - trim it to fit with a new sharp razor.
Jul 31, 2012 at 01:13 PM
