jnmimages Offline Upload & Sell: Off
p.1 #13 · Broken Hotshoe on 430 ex II Need assistance! | |
omarlyn wrote:
jnmimages wrote:
Thanks again for the suggestions. I called Canon service and they were about $10 cheaper than the place listed above. I have the part ordered and should be able to fix it myself in 5 to 7 days.
Thanks again.
Good to hear!
Also, a little additional info: I don't think you should have the following issue since you should be receiving a complete assembled foot but just FYI, if you have to disassemble the part with the spring loaded contact pins, be VERY CAREFUL...they will pop out if you're not careful and you'll end up on your knees looking for some really tiny springs in your carpet (don't ask me how I know this!)
Omar
I won't question your knowledge . I believe that spring has already sprung however. Pretty much everything that could have popped loose did, so I believe all that is needed is to remove some screws, plug in a plug, and screw back in. Hopefully should be pretty cut and dry.
