Seamless and carpet
Robin Usagani
p.1 #1 · Seamless and carpet
So last weekend I installed seamless in my basement. I have carpet in the basement. Is there a product you guys use to put on the carpet so I can lay the paper on the floor? Something that doesnt look bad and safe if I leave toddlers in the basement without supervision.
Jul 07, 2012 at 05:05 AM
buckeyeguy1
p.1 #2 · Seamless and carpet
How about 4x8 sheets of white panel board? It's not very thick and might give a little if your carpet and pad is softer.
If you need something thicker, you could glue it to some thin plywood.
White Panel Board
Jul 07, 2012 at 06:26 AM
RDKirk
p.1 #3 · Seamless and carpet
I would use 3/4 plywood so you can put an adult (like yourself) on it.
I would also not leave any toddlers in the basement unsupervised.
Jul 07, 2012 at 11:45 AM
Robin Usagani
p.1 #4 · Seamless and carpet
How is my wife or I suppose to do house stuff? Only when they are in bed?
Jul 07, 2012 at 01:12 PM
cordellwillis
p.1 #5 · Seamless and carpet
Beautiful picture.
Jul 07, 2012 at 07:13 PM
Robin Usagani
p.1 #6 · Seamless and carpet
We wish we can afford a full time nanny hahahah.
Jul 07, 2012 at 07:35 PM
4honor
p.1 #7 · Seamless and carpet
The space where I rent for my studio has carpet, and the landlord won't let us change out to hardwood floor. So I just used that white panel board on top of a 4x8 plywood. I shoot models, and I wanted the girls to be able to stand on it with their pointy heels. I think some flat boards should be pretty safe with kids...
P.S. I used duct tape all around the edge of the plywood since it's not smooth and might cause splinters.
Jul 09, 2012 at 03:32 AM
LivLif
p.1 #8 · Seamless and carpet
BUMP
Jul 12, 2012 at 05:33 AM
JBPhotog
p.1 #9 · Seamless and carpet
Plywood is not totally flat, it may curve slightly which could cause you some issues. A better option and probably cheaper is MDF or what is commonly called particle board. It is available in 5/8" and 4'x8' sheets :http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100085453&R=100085453
It is engineered to be flat and may in be harder than plywood should you be shooting ladies in high heels.
Jul 12, 2012 at 06:03 PM
