Archive 2012 · Image compression for the web
kazinvan
p.1 #1 · Image compression for the web
I just did a quick test between Lightroom, Photoshop, JPEGmini, and Smush.it to see what worked the best for posting images online. View the results here: http://photokaz.com/2012/06/image-compression-for-the-web/
Jun 12, 2012 at 06:02 PM
JohnnyMike
p.1 #2 · Image compression for the web
Would it be too much to ask if you can post your results here in this post?
Thanks in advance.
Jun 12, 2012 at 11:00 PM
kazinvan
p.1 #3 · Image compression for the web
The final results are below, though I think posting all of the images and text here is really more trouble than it's worth since it's all online already.
BEST: Photoshop Save for Web & Devices. No other optimization needed.
GOOD: Lightroom export with JPEGmini optimization.
CRAP: Smush.it. Not worthwhile for any images.
Jun 12, 2012 at 11:16 PM
Mickey
p.1 #4 · Image compression for the web
Doesn't "Best" strip the EXIF data from the image? I'm just asking.
Jun 14, 2012 at 06:47 AM
kazinvan
p.1 #5 · Image compression for the web
It will only strip if you tell it to. There is a "metadata" pull down where you can select how much info you want in there.
Jun 21, 2012 at 08:37 PM
