Roland W Offline Upload & Sell: On
p.1 #8 · which variable ND filter? | |
All variable neutral density filters have problems when you get to wider angles, with a weak but distinctive X shaped pattern showing up across the main part of the image. The effect shows up starting at a focal length of about 24 mm, and gets fairly strong when you get to very wide angles. And note that this issue is different than straight vignetting in the corners caused by the diameter of the filter being too small. Here is one previous thread that shows the X effect:
http://www.fredmiranda.com/forum/topic/1070123/0?keyword=variable,nd#10179083
