Archive 2012 · The big picture
ben egbert
p.1 #1 · p.1 #1 · The big picture
Yesterday I showed my sunrise shots from Silver Lake Flats. They were shot at 50 and 70mm which is about right for making Mt Timpanogos the prominent subject.
But as I was doing so, a great scene unfolded along the rest of the Wasatch bordering the water. So I did one with my 17TSE and another as an 11 shot pano using my 70-200 at 70mm vertical.
In hind sight, the 50 would have been a better choice as the 70 cut off part of the right side view.
Both techniques cause some perspective distortion with the 17 spreading the edges and the 70 compressing them. The truth is between the two presentations.
May 16, 2012 at 02:36 PM
TripleYYY
p.1 #2 · p.1 #2 · The big picture
Ben these are both lovely. The second one really stands out.
Y
May 16, 2012 at 02:55 PM
Zeph
p.1 #3 · p.1 #3 · The big picture
I like the color/mood of the first, but the crop/comp of the second....
scraptag
p.1 #4 · p.1 #4 · The big picture
Gorgeous. Your processing is perfect. What program do you use, and how do you get such perfect color?
May 16, 2012 at 03:21 PM
ben egbert
p.1 #5 · p.1 #5 · The big picture
Thanks Zeph and Y, glad you like them, I lean to the 17mm but its good to hear other views. Maybe next time I will try my 24 which would give the same scene as the pano.
Forgot to mention, I was doing other shots with the 70-200, when I wanted to do the pano. I quickly went to manual to make sure all images were exposed the same, and dialed in exposure with the little wheel on top just like I do in AV mode. Rats, I ended up at f2.8 and only saw it when I got home.
But a large stitch like this covers up small IQ issues.
May 16, 2012 at 03:34 PM
ben egbert
p.1 #6 · p.1 #6 · The big picture
Well the processing is pretty simple. The 17 for example is a two image blend. But I was able to use the bright image for everything but the sky and the top of the mountains so Painting in the darker sky and mountain tops was pretty easy. No filters used and the light was not that difficult to manage.
I get all my sharpening (other than a final one after downsize) in ACR. I use a wee bit of shadow highlight in Photoshop, a curves adjustment with attention to black point and add a wee bit of saturation with Topaz Color pop. I always go back and make sure I have a good black point when finished. This makes a lot of difference when DR has been worked.
The pano was only hard because it takes a long time to stitch 11 images. I had to save and reboot to free up some memory after it was stitched and made a half size for final processing.
But the exposure needed little help. I did have to clone in some sky and water to get a decent crop. It shows on full size. A print would need more work,
May 16, 2012 at 03:43 PM
HiredGoon
p.1 #7 · p.1 #7 · The big picture
Great shots, Ben.
I prefer the first image as it really captures the colours that we saw on the range to our right as the sun came out.
May 16, 2012 at 03:48 PM
ben egbert
p.1 #8 · p.1 #8 · The big picture
HiredGoon wrote:
Great shots, Ben.
It does, and I think I like it better than the 50 and 70 I showed yesterday. I was wondering if I could get further east and back from the lake a bit and do this with a 24. Bring a chain saw and clean up the bank a bit?
The one I did of that right edge with a 35mm looks all scrunched up. I saw some clouds this moring, might have been a better day.
May 16, 2012 at 03:53 PM
Camperjim
p.1 #9 · p.1 #9 · The big picture
Both are great. The color and reflection are better in the first, but I like the somewhat tighter crop of the second. Nitpicking. Both are great.
May 16, 2012 at 04:26 PM
gordon l
p.1 #10 · p.1 #10 · The big picture
That first shot is really nice. The glow on the mountains make it my choice.
gordon
May 16, 2012 at 04:41 PM
ben egbert
p.1 #11 · p.1 #11 · The big picture
Thanks Jim and Gordon, looks like a pretty even split on preferences. Color competing with composition.
The stitch was 11 images, but I had to toss out the last two on the right because they cut off too much top and bottom. Otherwise it would have the same stuff as the 17mm shot.
May 16, 2012 at 05:42 PM
joeyvu
p.1 #12 · p.1 #12 · The big picture
Nice images, Ben...Would be nice if we can combine both...They looks awsome...
May 16, 2012 at 05:52 PM
JimFox
p.1 #13 · p.1 #13 · The big picture
Hey Ben,
I like the tighter view of #2 here, though the glow in #1 is pretty nice. Maybe a bit too much sky in #1?
Jim
May 16, 2012 at 05:53 PM
Johan_E
p.1 #14 · p.1 #14 · The big picture
I like the abstract look of the first one. Very cool! Keep it up.
May 16, 2012 at 06:22 PM
helenica
p.1 #15 · p.1 #15 · The big picture
Nice shots Ben. I prefer the cropped version.
May 16, 2012 at 07:54 PM
SierraLover
p.1 #16 · p.1 #16 · The big picture
Nice Ben. My only quibble is that both photo's are being cut in half by the shore line.
May 16, 2012 at 08:00 PM
ben egbert
p.1 #17 · p.1 #17 · The big picture
JimFox wrote:
Hey Ben,
Jim
Hi Jim, thanks for the comment and you are right on the first one and I even thought of this before posting.
I level the camera and compose after choosing the appropriate lens. Being a 17TSE, I could have shifted it down, but that might have gotten my tripod legs :-) In the full size you can see the rocks in the shallow water at my feet. That leaves just the sky to work with. I did crop it to a 16x9 ratio (one of my frame sizes and took it all off the sky. UWA often provide too much foreground and sky.
Sounds pretty mechanical, I should crop per aesthetic value rather than to fit a frame I have. And perhaps I would. Or maybe I should crop it more like the second one which is preferred, or maybe even use a different lens. One advantage of zooms is better composition.
May 16, 2012 at 08:04 PM
ben egbert
p.1 #18 · p.1 #18 · The big picture
Thanks, and I can crop to the second look but of course with some different perspective. I may do that later and post it.
May 16, 2012 at 08:06 PM
ben egbert
p.1 #19 · p.1 #19 · The big picture
Glad you like it, my favorite too although we seem in the minority.
ben egbert
p.1 #20 · p.1 #20 · The big picture
Thanks, another vote for the tighter look.
May 16, 2012 at 08:07 PM
