Archive 2012 · Contax 85 F1.4 PLANAR or Canon FD 85L?
GC5
p.1 #1 · Contax 85 F1.4 PLANAR or Canon FD 85L?
Looking to pick up a fast 85mm for my NEX system. I was focused primarily on the lenses listed in the title. Does anyone have any comparison or experience with these? Anyone used one on a NEX?
Thanks
May 15, 2012 at 10:12 AM
rsrsrs
p.1 #2 · Contax 85 F1.4 PLANAR or Canon FD 85L?
i would also consider the samyang 85mm 1,4.
i like it quite a lot on my 7
reinhard
May 15, 2012 at 10:29 AM
Kay89
p.1 #3 · Contax 85 F1.4 PLANAR or Canon FD 85L?
85L....i don't have the 85P but i have the C/Y 85 1.2 and they are not much different!
Others may not agree with me!! but the fd 85L is sharp!
Svenning
p.1 #4 · Contax 85 F1.4 PLANAR or Canon FD 85L?
Find a second-hand Contax/Yashica 85mm Planar F/1.4
Believe it will give you a 170mm lens on you NEX.
From F/2.0 you will get very good pictures.
F/1.4 can be a little bit soft - however a lot of people prefer that when shooting portraits.
May 15, 2012 at 10:46 AM
ken.vs.ryu
p.1 #5 · Contax 85 F1.4 PLANAR or Canon FD 85L?
contax since you can use it on eos bodies easily.
May 15, 2012 at 10:48 AM
p.1 #6 · Contax 85 F1.4 PLANAR or Canon FD 85L?
I recommend the Contax Carl Zeiss Planar 85mm f/1.4 C/Y, too.
I have one, and I also have a Canon 85L II, Rokinon (Samyang) 85/1.4, and Leica Summicron-R 90/2. The Planar was my first, and I think it was a great start.
May 15, 2012 at 12:12 PM
ZoneV
p.1 #7 · Contax 85 F1.4 PLANAR or Canon FD 85L?
I have the Zeiss Contax 85/1.4 AE and the FD 85/1.2L.
The Canon is a bit optical modified for the use with my EOS 5D.
The Zeiss is a good lens, but the iris of the AE version is bad, because of the zig zag form of the bokeh at some f-numbers. And the quality for near field is not very good - I love to work with extension tubes, and there it sometimes sucks.
The FD is much better at this.
But I love the Zeiss at the moment more - a bit smaller, and I think a bit better focusing mechanism.
May 15, 2012 at 12:13 PM
GC5
p.1 #8 · Contax 85 F1.4 PLANAR or Canon FD 85L?
I hadn't thought about the Rokinon, but that may be a good option if it is in the ballpark optically. I already have an eos adapter for my Rokinon fisheye.... could pick up something else with the considerable savings...
May 15, 2012 at 12:19 PM
p.1 #9 · Contax 85 F1.4 PLANAR or Canon FD 85L?
ZoneV wrote:
...The Zeiss is a good lens, but the iris of the AE version is bad, because of the zig zag form of the bokeh at some f-numbers.
Good point. The AE version has "Ninja star" bokeh highlights at slightly closed down apertures. Look for the MM version, which has green numerals on the "16" aperture label, instead of the white labeled 16 on the earlier AE version.
May 15, 2012 at 12:20 PM
Jman13
p.1 #10 · Contax 85 F1.4 PLANAR or Canon FD 85L?
In my experience the Rokinon/Samyang is better at wider apertures than the C/Y 85/1.4, but the Zeiss is better from f/2.8-f/5.6 (though the Rokinon is not bad here either). Overall, I prefer the rendering from the Rokinon. I've owned two C/Ys, an AE and an MM, and both were essentially identical except for the ninja star bokeh on the AE at f/2-f/2.8.
May 15, 2012 at 01:17 PM
GC5
p.1 #11 · Contax 85 F1.4 PLANAR or Canon FD 85L?
Thanks all. I just picked up a Rokinon. I may still try the others though. I seriously covet the L (just as I do its EOS cousins). But the Rokinon should do what I need for now and I saved enough cash to pick up a few FD mount toys to go along with it.
Edited on May 15, 2012 at 03:34 PM · View previous versions
May 15, 2012 at 02:28 PM
ZoneV
p.1 #12 · Contax 85 F1.4 PLANAR or Canon FD 85L?
I would not recommend Samyang.
I own the 14/2.8 and read much about the other versions.
The 85/1.4 has sometimes a stuck iris. Now the people that sell this lens used sometimes even write "no stuck iris" or "iris stuck only one time, but since then ok". Furthermore on this lens the bokeh is not at every lens ok. It is a aspherical lens, but has not the onion rings like most better aspherical lenses. Sometimes it is wooly structure - I think mostly to see with colored artifical light. I think because of the hybrid aspherical lens.
The bokeh is another thing the Zeiss has better than Canon FD L for me - I donīt like onion rings. This is a reason why I like the Rokkor 58/1.2 that much.
May 15, 2012 at 02:38 PM
GC5
p.1 #13 · Contax 85 F1.4 PLANAR or Canon FD 85L?
Too late. I alread ordered the Rokinon (though used and from a place I can return it). If I understand you correctly, you are saying that the bokeh is not good because it does not have "onion rings" like some expensive fast aperature lenses. As I strongly dislike onion ring bokeh, that seems sehr gut to me. If it does have that issue, I'll return it. Onion rings are a problem not a feature I desire.
May 15, 2012 at 03:22 PM
p.1 #14 · Contax 85 F1.4 PLANAR or Canon FD 85L?
Hmmm. In my experience. and this is shared by many other Alt-minded folks in posts when the Rokinon 85/1.4 was new kid on the block, the Rokinon is bokeh king. It's not quite as sharp as the Planar (and 'Cron) at smaller apertures, as mentioned by Jordan, and it doesn't have the Zeiss microcontrast (whatrever that is), but wide-open, the Rokinon consistently renders usually-nasty backgrounds as smooth and dreamy. Hence, "bokeh king".
https://www.fredmiranda.com/forum/topic/952008
P.S. I own both the Samyang 14/2.8 and Rokinon 85/1.4. The Samyang 14mm is fantastic. The Rokinon 85/1.4 is bokeh king. My other 80mm to 105mm lenses are all good; each has it's own place.
May 15, 2012 at 03:32 PM
briantho
p.1 #15 · Contax 85 F1.4 PLANAR or Canon FD 85L?
Canon FD 85L was one of the first lenses I ever bought. This was about a year ago. Since then I have become a huge Zeiss fan, and I've sold almost all my non-Zeiss glass, but the 85L is one lens I don't intend to sell. I like it so much, I see no reason to replace it with the CY 85 1.4.
I had the ZF85 for a few weeks, but I decided the Canon was a better lens for me, and I sold the ZF.
May 15, 2012 at 03:45 PM
p.1 #16 · Contax 85 F1.4 PLANAR or Canon FD 85L?
briantho wrote:
... I see no reason to replace it with the CY 85 1.4...
I prefer non-exclusive partnerships.
May 15, 2012 at 04:04 PM
ZoneV
p.1 #17 · Contax 85 F1.4 PLANAR or Canon FD 85L?
Sorry for my bad English:
I donīt like onion rings too. Because this I like the Zeiss Contax 85/1.4 (and the Minolta Rokkor 58/1.2) because they donīt have aspherical lenses, and so no onion rings or worse things.
I saw images made with the Samyang 85/1.4 with a structure even worse than onion rings, looks like a wool-ball.
Examples:
http://www.flickr.com/photos/14872705@N02/6217429594/
http://forums.dpreview.com/forums/readflat.asp?forum=1043&message=39623400&changemode=1
And here with the Samyang 35/1.4
http://www.eoshd.com/content/3436/samyang-35mm-f1-4-ed-as-umc-review-canon-mount
http://www.flickr.com/photos/eoshd/5951366012/
http://steveoakley.net/template_permalink.asp?id=422
And Samyang 24/1.4
http://www.lenstip.com/330.7-Lens_review-Samyang_24_mm_f_1.4_ED_AS_UMC_Coma__astigmatism_and_bokeh.html
I think it is not visible under most conditions. And it looks like most lenses are ok with normal onion ring bokeh, but some of the Samyang 85/1.4 seem to have this wooly bokeh.
May 16, 2012 at 02:32 AM
Peire
p.1 #18 · Contax 85 F1.4 PLANAR or Canon FD 85L?
Contax 85/2.8 Sonnar and ZF 85/1.4 Planar do very well on my 7 and 5Ns.
May 16, 2012 at 10:13 AM
