Archive 2012 · Lovin The D800's built-in HDR -new one
grosema
p.1 #1 · p.1 #1 · Lovin The D800's built-in HDR -new one
Looks good on my 42 inch monitor
it would have taken me a long time to do this with 2 pictures manually and It would not have been this good
here is another one it was a shade darker I did not even look at it before I posted the first one
The new one is on top
http://www.pbase.com/grosema/image/143249904/original.jpg
http://www.pbase.com/grosema/image/143247673/original.jpg
Edited on May 12, 2012 at 04:14 AM · View previous versions
May 12, 2012 at 12:14 AM
Avi B
p.1 #2 · p.1 #2 · Lovin The D800's built-in HDR -new one
So was it via tone-mapping?
May 12, 2012 at 12:31 AM
myam203
p.1 #3 · p.1 #3 · Lovin The D800's built-in HDR -new one
He means the D800's built-in HDR capability.
May 12, 2012 at 12:36 AM
grosema
p.1 #4 · p.1 #4 · Lovin The D800's built-in HDR -new one
Yes Sorry
May 12, 2012 at 12:39 AM
mawyatt
p.1 #5 · p.1 #5 · Lovin The D800's built-in HDR -new one
Very nice. What lens did you use.
May 12, 2012 at 12:47 AM
capt3450
p.1 #6 · p.1 #6 · Lovin The D800's built-in HDR -new one
On EXIF said he use 24 f/1.4
May 12, 2012 at 01:09 AM
Creative Edge
p.1 #7 · p.1 #7 · Lovin The D800's built-in HDR -new one
Looks good, very natural not overly done
May 12, 2012 at 01:34 AM
Zebrabot
p.1 #8 · p.1 #8 · Lovin The D800's built-in HDR -new one
the sunny parts are still way blown out.
May 12, 2012 at 01:53 AM
zqfmbg
p.1 #9 · p.1 #9 · Lovin The D800's built-in HDR -new one
They are? I don't see big monochrome blotches...
I always found it funny that "high dynamic range" is used to refer to a process where you're actually compressing the range in a photograph.
May 12, 2012 at 02:14 AM
Hardcore
p.1 #10 · p.1 #10 · Lovin The D800's built-in HDR -new one
I have 2 calibrated monitors and both of them are not showing the blown highlights. Image looks great to me. I will have to try this feature.
OP, what kind of smoothing did you use?
May 12, 2012 at 02:29 AM
curious80
p.1 #11 · p.1 #11 · Lovin The D800's built-in HDR -new one
Actually the HDR process does exactly what it is called - combine multiple images to create a high-dynamic-range image containing a larger range of intensities than possible in a single capture. There is then a separate process called tone mapping which compresses the range in the HDR image to create final low-dynamic-range image. Its a common abuse of terminology to called the final image as HDR, even though the HDR image is the intermediate one which you never directly see.
May 12, 2012 at 02:30 AM
passthegravy
p.1 #12 · p.1 #12 · Lovin The D800's built-in HDR -new one
Was this done with just 2 exposures? Does the D800 allow you to set the number of exposures to be blended into the HDR image? If so, what is the max number of exposures?
Finally, does the D800 save all of the images plus the HDR version separately, or does it just save the one HDR image?
(Sorry for all the questions.)
May 12, 2012 at 03:08 AM
galenapass
p.1 #13 · p.1 #13 · Lovin The D800's built-in HDR -new one
The only thing that is "blowing" here is your comment.
May 12, 2012 at 03:10 AM
Bruce Sawle
p.1 #14 · p.1 #14 · Lovin The D800's built-in HDR -new one
+1 looks perfect on my two monitors and the iPad.
May 12, 2012 at 03:13 AM
Zebrabot
p.1 #15 · p.1 #15 · Lovin The D800's built-in HDR -new one
must be your eyes.
May 12, 2012 at 03:16 AM
myam203
p.1 #16 · p.1 #16 · Lovin The D800's built-in HDR -new one
Okay I guess I have to be the one to settle this. I pulled the image into PS and there are some blown out spots for sure--mainly the bright area of sidewalk against the building in the center of the image. The numbers don't lie.
May 12, 2012 at 03:24 AM
galenapass
p.1 #17 · p.1 #17 · Lovin The D800's built-in HDR -new one
..and those are the spots with sun on them. Surprise!!! What's the point here? There is tremendous dynamic range in this shot, which, on a camera without an HDR feature would be complete darkness under the tree with a few blown out highlights in the direct sun - or worse.
Do we see that here? No. End of story.
Great shot. Thanks for posting something useful which demonstrates a feature of a new and interesting camera.
May 12, 2012 at 03:37 AM
myam203
p.1 #18 · p.1 #18 · Lovin The D800's built-in HDR -new one
Hey, I'm just the messenger here. However, the D800 has such amazing dynamic range that I wonder how much shadow detail could be pulled out of this shot if you exposed for the highlights.
May 12, 2012 at 03:40 AM
Bruce Sawle
p.1 #19 · p.1 #19 · Lovin The D800's built-in HDR -new one
Zebrabot wrote:
must be your eyes.
Zebra you have not changed a bit. Once an A hole always!!
galenapass
p.1 #20 · p.1 #20 · Lovin The D800's built-in HDR -new one
Hey Mike you are just getting caught in the crossfire with Zebra's butt.
However, you do raise a good question. I wonder if the OP is in a position to answer this?
May 12, 2012 at 03:46 AM
