Archive 2012 · Adding chip to Nik 50mm 1.2 AIS
nategigapixel
p.1 #1 · p.1 #1 · Adding chip to Nik 50mm 1.2 AIS
Just wondering if anyone has done this and has any tips. It looks to be a little more challenging with the larger rear element. Haven't had any luck finding sources online.
May 10, 2012 at 10:35 PM
olivier13
p.1 #2 · p.1 #2 · Adding chip to Nik 50mm 1.2 AIS
I dont think that its possible to add any of the conventional [dandelion?] chips to this lens, as you've noticed the rear element is too large to accomodate one. Just have to live with what metering you can on the modern bodies, I understand this lens is a treat on the d700.
May 10, 2012 at 11:09 PM
Mishu01
p.1 #3 · p.1 #3 · Adding chip to Nik 50mm 1.2 AIS
I think this is a difficult task. I want to do it but no courage for now... Look on this thread:http://forums.dpreview.com/forums/readflat.asp?forum=1030&message=36768079&changemode=1
May 10, 2012 at 11:11 PM
nategigapixel
p.1 #4 · p.1 #4 · Adding chip to Nik 50mm 1.2 AIS
Yes, that's the only source where I've seen someone do it successfully, which is hopeful. thanks
May 10, 2012 at 11:33 PM
Chris Dees
p.1 #5 · p.1 #5 · Adding chip to Nik 50mm 1.2 AIS
I have my copy chipped by a friend. He had to grind a little bit of the glass.
All my MF lenses are (being) chipped, except the 16FE (it's a worn-out copy).
He even chipped the 58 Noct.
His nickname is 'doctor lens'. :-)
May 11, 2012 at 07:04 AM
j.liam
p.1 #6 · p.1 #6 · Adding chip to Nik 50mm 1.2 AIS
If you look at Rorslett's commentary, the 50/1.2 isn't one that lends itself to chipping. The NOCT can be but with serious surgery on the rear element, if you have the stomach to do that on a $3000 irreplaceable item.
May 11, 2012 at 01:40 PM
Chris Dees
p.1 #7 · p.1 #7 · Adding chip to Nik 50mm 1.2 AIS
Here's the topic of chipping the Noct.
I don't know if it's the paid part of the website.
May 11, 2012 at 02:05 PM
williamkazak
p.1 #8 · p.1 #8 · Adding chip to Nik 50mm 1.2 AIS
Oh man, is anyone ever happy with what they have got?
May 11, 2012 at 02:09 PM
nategigapixel
p.1 #9 · p.1 #9 · Adding chip to Nik 50mm 1.2 AIS
that's the spirit!
May 11, 2012 at 05:03 PM
AMaji
p.1 #10 · p.1 #10 · Adding chip to Nik 50mm 1.2 AIS
Drop these guys an email. They replied to mine within a matter of hours and their rates seem very reasonable. Hope this helps.
http://legacy2digital.com/nikon/convert-my-lens
May 11, 2012 at 06:30 PM
