Archive 2012 · HS Flash Sync w/SB-910 + D800
CMOS
p.1 #1 · p.1 #1 · HS Flash Sync w/SB-910 + D800
I was trying to use high-speed flash sync with my D800 + SB-910. As far as I could tell, you can't run HS sync in aperture priority mode? I could get shutter speeds over 1/60 in shutter priority and other modes I think, just not A.
I had the camera set for the Auto FP, as I think it was called.
Is that right, or am I missing something?
May 10, 2012 at 04:04 PM
CMOS
p.1 #2 · p.1 #2 · HS Flash Sync w/SB-910 + D800
Nevermind, got this figured out.
May 13, 2012 at 07:26 PM
Steve Beck
p.1 #3 · p.1 #3 · HS Flash Sync w/SB-910 + D800
What was the cause of your issue?
May 13, 2012 at 09:16 PM
CMOS
p.1 #4 · p.1 #4 · HS Flash Sync w/SB-910 + D800
Not sure. I didn't change any settings. Was probably turning the wrong function dial or something like that
May 13, 2012 at 09:53 PM
Steve Beck
p.1 #5 · p.1 #5 · HS Flash Sync w/SB-910 + D800
Hahah... Yeah, I feel at home more with my d800 interface more so than my d700. Lots of options though in the menus. I dd so prom shot outside this weekend. I usually use very sting trash to over power the sun and or sky so I can expose on the sky and still get my subject exposed nice with no alot blown out. This d800 is simply amazing. I used a little fill flash and -1/3 exp. comp.. The sky fell in nicely with LR and I didn't have to blow
Y flash up tying to achieve this in camera.
May 14, 2012 at 12:30 PM
