Archive 2012 · PBG from this morning
Enriquepb
p.1 #1 · p.1 #1 · PBG from this morning
been getting up early these days... I find that birds are much more cooperative before people start showing up...
http://i1124.photobucket.com/albums/l571/EnriquePB/_MG_8985-Edit-1024.jpg
Apr 29, 2012 at 12:50 AM
Enriquepb
p.1 #2 · p.1 #2 · PBG from this morning
the image above is nearly FF
here is a 100% crop with only the default sharpening in Lightroom... otherwise processed in a similar fashion as the original... using a 7D + 300mm F/4 + 1.4TC
I think it is good, but would like to hear what you think...
http://i1124.photobucket.com/albums/l571/EnriquePB/_MG_8985-100percent.jpg
Apr 29, 2012 at 01:26 AM
p.1 #3 · p.1 #3 · PBG from this morning
Nice set !
Apr 29, 2012 at 03:04 AM
B Benson
p.1 #4 · p.1 #4 · PBG from this morning
Looks great Enrique, I bought Ibird after talking to you today. Bruce
Apr 29, 2012 at 03:17 AM
Jonathan Huynh
p.1 #5 · p.1 #5 · PBG from this morning
Great!
Apr 29, 2012 at 03:18 AM
David Leask
p.1 #6 · p.1 #6 · PBG from this morning
Very nice indeed Enrique. Great detail in the close-up too
David
Apr 29, 2012 at 07:19 AM
kmunroe
p.1 #7 · p.1 #7 · PBG from this morning
great job Enrique
Apr 29, 2012 at 11:11 AM
surfnron
p.1 #8 · p.1 #8 · PBG from this morning
Nice Enrique. The crop looks good for 400 ISO, but just not quite s good as I would like. I shoot a 7D too and find 100% crops could be a tad bit better. I hope Tony chimes in on this one ~ Ron
Apr 29, 2012 at 12:46 PM
KCollett
p.1 #9 · p.1 #9 · PBG from this morning
It is a good shot Enrique. Well done.
Apr 29, 2012 at 02:25 PM
sritri
p.1 #10 · p.1 #10 · PBG from this morning
This is very good Enrique. Maybe a little MA could make it sharper. My wife shoots the same combo and +4 gives superb results. However AF suffers
And also I have found soaking wet ducks do seem less sharp on 100% crops
Apr 29, 2012 at 03:04 PM
DonGut
p.1 #11 · p.1 #11 · PBG from this morning
That is a fine portrait. I think the detail is quite good and won't detract from a larger version! Don
Apr 29, 2012 at 06:39 PM
Enriquepb
p.1 #12 · p.1 #12 · PBG from this morning
Thanks for your comments. I will try printing it 12X18 and see how it looks...
Apr 29, 2012 at 07:22 PM
Benzzene
p.1 #13 · p.1 #13 · PBG from this morning
Seeing you are using a 1.4 with the 300 f4.0, your results are pretty good at 100%. Remember, the 300F4.0 is not a top of the line L-series lens, so using the 1.4 will not be as sharp as if you were using a 300F2,8. Also,run the file through a noise reduction application as this will increase your resolution as well...If you're not making ginagorous prints then "what difference does it make?" Benzzene
P.S. don't hang out with Bruce too much! Look what happened to me when I had to hang out with him because he was my older brother!!
Apr 30, 2012 at 12:56 AM
p.1 #14 · p.1 #14 · PBG from this morning
No bugs in the feathers :-}
Nice image
Apr 30, 2012 at 01:18 AM
ashley138
p.1 #15 · p.1 #15 · PBG from this morning
Great shot!!
Apr 30, 2012 at 05:30 AM
speedmaster20d
p.1 #16 · p.1 #16 · PBG from this morning
very nice
100% crop looks good for sharpness. There is CA (color fringing) you can correct in LR.
Apr 30, 2012 at 07:30 AM
rocco61
p.1 #17 · p.1 #17 · PBG from this morning
Lovely work
Apr 30, 2012 at 09:18 AM
